Old 08-19-2008, 08:33 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
DV - Carb & Ignition Eco-tuning Made Easy
David Vizard starts out with a nice write up done on how to tune a carburator for best fuel economy. He also explains how to time the engine for best economy.
I don't necessarily agree with his ideas about leaning out as far as possible as this can significantly raise NOx emissions, but it will get you better fuel economy.
#2 Eco-tune carburated V8's - fast and accurate - GoFastNews.com
Old 08-29-2008, 09:50 PM   #2 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
very lean is good if you have another something to go with it. water for lean can even make old sloppy v8s hit the 30s. Nox emissions is rather bizarre to focus on. the atmosphere is mostly this...to return a chemistry back to it is the smartest way to go.
Old 08-30-2008, 01:34 PM   #3 (permalink)
Blue - '-1823 P/U
i got so lean i got miss-fires,,not good
Old 09-09-2008, 09:53 PM   #4 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Got a source?
Not doubting, I just want to see some more data.
6 speed ALH TDI
Old 09-09-2008, 10:08 PM   #5 (permalink)
Philthy
craggin' wagon - '01 Outback
i'm pretty sure the atmosphere is something like 74% Nitrogen (N2), where as Nitrous Oxides are an entirely different animal which cause a lot of pollution and, if im not mistaken, are one of the main causes behind acid rain...so it is kind of important.
