Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 03-10-2008, 10:39 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
couldn't you get an electric scooter and swap parts from it? doesn't seem to be that complicated on those things, although I don't know exactly the quality on them, but they're fairly cheap for the "lower end" ones.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 03-11-2008, 12:16 AM   #12 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
most of the scooters that I have looked at are pretty low quality, with small motors, small batteries and limited speed control and they get around that buy having a low top speed, and with a small motor you just run wide open all the time and push it up hills.
Check Ebay for motors, and maybe post an ad on craigslist looking for stuff to play around with, but I wouldn't bother putting less then a 1hp motor on a bicycle any more, that comes out to 750-1,000 watts.
I've talked to the owner of http://www.neodymics.com/ before, and he has some interesting ideas, I agree that the price is more then most people are willing to spend, but it's made with quality parts, and hopefully he'll find a market.
Old 05-02-2009, 11:50 PM   #13 (permalink)
tasdrouille,
i'm looking for a similar set-up for my bike. i was also thinking about getting the zap. it looks like the best option at the end of the day. inexpensive with a simple design. did you get have any luck with anything?
ryland,
if the max speed of the zap is 15mph then does that mean that any additional peddling will simply add to that speed? Say I pedal as hard as I normally do and I normally travel at about 10mphs and then I add the zap will I be going at 25mph?
thanks!
Old 05-03-2009, 12:34 AM   #14 (permalink)
Ryland's Avatar
thanks!
ZAP motor, not pedaling I would go 12-15mph, I could hit 20mph if I tried hard, but about 17-18mph was normal flat road speed pedaling with normal effort.
With the crystalite motor from electricrider.com I've seen 37mph with the high speed motor at 48 volts, and 27mph with the mid speed motor at 36 volts, no pedaling for either motor.
Old 05-03-2009, 01:24 AM   #15 (permalink)
Christopher Jordan's Avatar
Gopher (aka- go fer...) - '95 Aspire 2dr hatch
My throttle control broke. I had a new one put on last week, and it got much slower. I thought I could pedal harder and that would bring it up to previous speed. WRONG. My E-Pod seems to have some sort of restrictors in the controller or hub.
E-Pod to E-Slug in one week.... not even pedaling harder helped.
Old 05-03-2009, 09:33 AM   #16 (permalink)
bryn's Avatar
sputnik - '93 silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 clubwagon E-350 xlt
very excelant - '92 civic vx
for ease of removal,
just convert a cheap scooter into something like a bob trailer
change the final drive for top speed,
extend controls with a quick disconnect
that way you have room for groceries, a briefcase, tool box, whatever you need at work
you can still go ride on the weekend without the extra weight
Old 05-03-2009, 09:35 AM   #17 (permalink)
bryn's Avatar
i got a 400 watt scooter for $50 at a pawn shop because it needed a charger
Old 05-03-2009, 10:46 AM   #18 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
You might be able to build a friction drive e-bike for $300.
Friction drive meaning you put a tube on the driveshaft of the motor and push it against the tire to move the bike. With gas motors, people typically use bmx bike pegs (the ones that you see attached to the wheel shaft of small bikes) and mount the pegs to the motor shaft. You can also use epoxy mixed with sand on any shaft to provide friction. Friction drives don't work as well in rain.
You would have to figure out the gear ratio on an electric motor. The motor would have to be held in a frame that pivots and can be held down against the tire, or can be lifted up for free pedaling with no motor drag.
You might find a 1 kW motor for $50. Hopefully you have a lot of junk in your workshop that can be transformed into parts for a frame and driveshaft. 48V and 12 amp hours of lead acid will run you about $150. A 48V charger another $150, but you can also disconnect things and run multiple cheap 12V chargers if you have them available (this is a pain). Wiring needs to be 12 gauge (minimum) or 10 gauge (preferred), hopefully you have this in your junk drawer.
Nissan Versa Aeromods
Why Electric Bikes? GenKreton Alternative Transportation 26 08-05-2011 03:12 AM
Summer FE options - Scooter, bike assist, etc friedlbug Alternative Transportation 16 02-20-2009 01:41 AM
Bike riding at night - pointers. AndrewJ Alternative Transportation 9 03-30-2008 02:24 AM
The Ultimate Commuter Bike NoCO2 Alternative Transportation 13 02-29-2008 12:45 PM
lack of Bike Racks (for parking/locking to) Lazarus The Lounge 4 01-16-2008 01:49 AM
