12-23-2015, 07:21 PM
#11 (permalink)
PSmodder lurker
It's natural 'Murican mid-engined supercar rival is the $400K 2017 Ford GT, with its gorgeous flying buttress design, full-carbon fiber structure and body panels, 7-speed dual-clutch automatic and somewhat strange-sounding to 'Murican ears, a V-6.
12-23-2015, 07:26 PM
#12 (permalink)
But the GT has its rear-engine feature as a tradition since the original GT40, so it makes sense to have a rear-mounted engine. The 'Vette, OTOH, wouldn't be the same with a rear engine...
12-23-2015, 07:47 PM
#13 (permalink)
1.0L in a 'Vette sounds odd, as this displacement range is seen as a povertry feature in my country.
It was to establish a lower bound. To paraphrase Bill Gates, 1.6 liters should be enough for anybody.
Just add 300kW in electric motors and an 85kWh battery pack.
12-23-2015, 08:58 PM
#14 (permalink)
In 1947 Ferrari shipped a 1497cc V12. This suggests a 1-liter V-8 is possible.
Aussies already make a 1.0 V8:
Ian Drysdale’s Spectacular Drysdale 1000 V8
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
12-23-2015, 10:08 PM
#15 (permalink)
I do not remember enough about the conversation to want to find it, but I believe someone told me that having many tiny cylinders (for deactivation?) created excessive friction losses.
12-23-2015, 10:44 PM
#16 (permalink)
Well, yes, the higher the number of cylinders, the higher the losses, more bearings, valves and followers. A 2x small pistons will have a greater circumference then a single bigger cylinder (of the same displacement), that means there's more surface area to run on the cylinder walls creating more friction. Think of a rubic's cube. How many faces would there be if each block was a separate cylinder?* Now think about how many faces are hidden when combined into a full cube?*
Most car 1.0's are 3 cylinders for a reason. My Fiat's a 2 cylinder
Maybe they'll go the Mustang route of a turbo 4?
*Answers: 162 vs 54 Ok, the tops and bottoms don't add friction, but you get the idea.
12-29-2015, 08:24 PM
#18 (permalink)
At least for the next decade I don't believe the 'Vette would get rid of pushrods definitely.
Anyway, it might sound like a pipedream, but a 2-stroke V6 similar to some outboard powerheads would be a nice powerplant for a 'Vette...
