Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-24-2009, 07:40 PM   #21 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
Originally Posted by Christ View Post
This is also why, when you want to keep heat in your house, you insulate the ceiling, not the floors.
One insulates the ceiling more because of the convection of air inside the house, but the walls and floor are still very important to keep in balance because there are more forms of heat transmission happening in the house than just convection. The ground below tends to be warmer than outside so there is a smaller ΔT but you'll still lose heat in that direction. The envelope of any heated or cooled structure is as good as its weak points. What happens if you install radiant heat and you don't insulate below the floor? Will it work as well?
Teaching Efficient Driving in School 93DelSol Hypermiling / EcoDriver's Ed 17 06-05-2010 09:49 PM
GPS Navigation Saves Gas Through More Efficient Route Selection SVOboy EcoModder Blog Discussion 0 05-04-2009 11:50 AM
Hello... I bought a truck, and need to make it more efficient GoodOak Introductions 8 04-16-2009 12:09 AM
Even With Cheap Gas, We Still Want Fuel Efficient Vehicles SVOboy EcoModder Blog Discussion 3 02-23-2009 02:56 AM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
