Old 01-14-2012, 07:01 PM   #11 (permalink)
dunno, i put those plugs in before i really payed attention i'm going to go with probably not though.
Old 02-17-2012, 02:54 PM   #12 (permalink)
I have had a set in my 98 Civic EX for a long time and they didn't make a lick of difference. I looked at them the other day when replacing plug wires and i should have picked a new set of plugs as well. Someone talked about indexing plugs in an earlier post that i think i would go that route instead of E3's again for my car.
Old 02-17-2012, 02:59 PM   #13 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
More ground electrode might prevent plug fouling, that's why they may improve small engine performance. A good engine doesn't burn very much oil, and plug fouling is not an issue. I run a regular NGK copper plug (indexed) in my 15 psi 300 whp Nissan turbo L28, and have not seen any misfiring up past 6000 rpm. And that same setup gets 29mpg cruising 70mph.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 03-10-2012, 07:26 PM   #14 (permalink)
Gealii's Avatar
Shortster - '00 intrigue GL
90 day: 20.67 mpg (US)
ZX2 - '99 Escort ZX2 HOT
Team ZX2
Have tried them did not make any noticeable difference
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 03-10-2012, 08:05 PM   #15 (permalink)
heading for 40
redorchestra's Avatar
The Kitten - '07 Focus ZX5 SES
90 day: 35.9 mpg (US)
a question for anyone running a scanguage ! is it able to tell any difference in the mpgs when you change plugs. I changed my plugs from the oem double platinum to a copper core and I felt a difference in the way the car ran and I saw a jump in tank to tank mileage . what difference would you see in the scangauge? does it automatically read these changes?
Old 03-12-2012, 12:47 AM   #16 (permalink)
The SG will read the pulse width sent to the fuel injectors, and the vehicle speed sensor reading. It won't detect changes in the spark, but if your engine truly does use less fuel to travel the same route, it should see that.
-soD
Old 03-12-2012, 08:42 PM   #17 (permalink)
radioranger
All those early hondas I worked on really used up plugs, at around 25 k miles they lose about 2 + MPG in my experience, I'm talking the 90's Honda Civics and Accord, I asked the dealer at the time 1991 and he said every 15 K was recommended, he was right milage on the Accord went up over 3 , on another note unrelated has anyone here looked up the old Mobil fuel economy Run results from the 50's and 60's could be interesting.
