Old 12-19-2013, 10:12 PM   #251 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
very impressive car and build thread!
tried to do a partial grill block on my echo and the temp went way up!
(on scangauge)
Past Present Future?
The Following User Says Thank You to alohaspirit For This Useful Post:
echo-francis (12-29-2013)
Old 01-12-2014, 03:18 PM   #252 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
some weeks ago, in my infinite quest of weight remove I installed a toyota yaris NST light weight pulley.
I noticed a increase in acceleration at about 2k rpm and more.
nothing big but butt dyno approved
the old pulley weight was 3.4-3.5 lbs and the new is 0.4-0.5 so its about a 3lbs reduction. but a VERY strategic 3 lbs reduction
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
The Following 2 Users Say Thank You to echo-francis For This Useful Post:
j12piprius (11-27-2014), jeff88 (01-12-2014)
Old 01-12-2014, 07:47 PM   #253 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Which pulley?
Old 01-12-2014, 08:07 PM   #254 (permalink)
40-60-40 MPH P&G
the crank shaft pulley
MPG=1 TIME=0
The Following User Says Thank You to echo-francis For This Useful Post:
California98Civic (01-12-2014)
Old 02-02-2014, 10:13 AM   #255 (permalink)
40-60-40 MPH P&G
this is me trying to do my best in the most hilly road I have drove.
the little red light left to my speedometer means EOC
no little red light mean pulse at about 80% LOD or engine breaking
sorry for the SG not lisible
MPG=1 TIME=0
Old 02-02-2014, 12:38 PM   #256 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Nice to see the pulley worked for you. The MOI at the crank is very low, so must gains are from underdriving the acc. I was lucky as d15z1 is non-dampened stock, so longevity shouldn't be affected. Is this the same on the echo?
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 02-02-2014, 12:51 PM   #257 (permalink)
Cyborg ECU
Nice job echo-francis!
Xntrx, by MOI are you refering to rotational mass in some way. A 3 lb reduction in rotational mass being equivalent to maybe 6 or even 12 lbs dead weight? And by dampened you mean no harmonic balancer? Or something else. Sorry for basic questions, but if I am asking then there must be other readers who don't quite recognize the terms, ether, right? I am actively considering this mod when I do scheduled timing belt work sometime in the near future, maybe March. I don't have AC or PS anymore and since the crank pulley has to come off for the timing belt replacement... maybe its a good time to mod it. Thanks man.
Old 02-02-2014, 01:09 PM   #258 (permalink)
40-60-40 MPH P&G
i dont know if my pulley is dampened or not but there are people on yaris world that have the same pulley for 50000 mi+ with no problem. and in my case there is no belt on the pulley so I dont think longevity is affected
MPG=1 TIME=0
Old 02-02-2014, 01:15 PM   #259 (permalink)
Sorry, MOI = Moment of inertia. The mass of a crank pulley is "tight" to the axis, reducing the leverage.
Dampened does equal a harmonic balancer of sorts (more of a dampening of harmonics in practice).
On a d16, don't do it. These are dampened, and may lead to damage. the reason they are dampened is the r/s ratio is worse do to the longer stroke. (*edit* r/s = rod to stroke ratio, with 1.75:1 being ideal. any lower/higher becomes more unstable).
The Following User Says Thank You to Superfuelgero For This Useful Post:
California98Civic (02-02-2014)
Old 02-02-2014, 01:42 PM   #260 (permalink)
Cyborg ECU
But if I had a lighter pulley that was dampened or balancer adequately the mod would be useful, you think? Remember that I have to remove the pulley, anyway, to do the timing belt. And I would be replacing a pulley that must be quite heavy, with useless PS and AC spaces on it. I bet it would be very hard to find a pulley light enough and well balanced for cheap enough to make it seem like a good idea.
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
