Old 04-10-2015, 12:29 AM   #301 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Exceptional combo of reused "junk" new parts and smart fit with everyday tools. Fun!
echo-francis (04-10-2015)
Old 04-18-2015, 11:17 AM   #302 (permalink)
cool picture. step by step working to the best result.
Old 05-13-2015, 03:38 PM   #303 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Update : The 1NZ-FE is out of the car for a complete engine rebuild, polish, cylinder re-honing, crankshaft balancing etc... Brand new Prius 1NZ-FXE pistons for higher compression. stay tuned for update on this when the engine will be in the car again.
Doing alot of modifications. Like a complete conversion to manual rack & pignion from a USA echo, 4-2-1 OBX headers with a new exhaust line, new cat (not legal in new-york and california) , hollowed out resonator + the glasspack that is already installed, new OEM engine, tranny and rear mounts, new fluids everywhere. complete engine bay + tranny cleanup while the engine is out. Some parts where sandblasted and re-painted black to cleanup rust.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
The Following 3 Users Say Thank You to HyperMileQC For This Useful Post:
deejaaa (05-13-2015), jeff88 (05-14-2015), ME_Andy (05-14-2015)
Old 05-14-2015, 06:12 PM   #304 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.23 mpg (US)
Do you need to use the FXE engine computer with the new pistons or can you still get away with the old computer?
Also, how does the rack and pinion help with mileage compared to what you have now?
Look forward to the mods! Good luck!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 05-15-2015, 01:06 AM   #305 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
small update before the big update
i just got back my engine
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 05-15-2015, 02:21 AM   #306 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
What made you decide to pull engine and rebuild...? I have notice that the particular engine you are/have rebuild sells in local salvage yards here for about $700 USA dollars give or take some. My local machine shop would want $600 or up to rework the cylinder block. Did you redo the vvt valve head on your own.?
Old 09-06-2015, 06:19 AM   #307 (permalink)
n/a - '05 Ford Focus ZX3
subscribe.
Old 11-16-2015, 05:45 PM   #308 (permalink)
40-60-40 MPH P&G
i am finaly posting 7month after the engine rebuild. I was hoping for record mpg this summer but it took me 6 months to realize that I had a exhaust leak because i was thinking it was normal that my car was louder because of my new cat and resonator and increased compression. but now my mpgs are better then last year for that temperature.
and I did a lot f things to my car in 7 month
but first, more pic of the rebuild
new 1nz-fxe pistons
new 4-2-1 headers
i wraped my new exhaust line and headers
it look like I have a lift kit when the engine and tranny are not in the car
i have changed my upper grill block and passenger mirror cover to black abs plastic and my whiper cover to black chloroplast
i have relocated all my batterys in the trunk
i replaced my front suspension
i replaced my rear bearings, cylinders, drums, shoes, and plates.
i made a new middle belly pan with side skirts but without rear wheel spats but now i can lift the car without removing the bellypan
the bellypan is made out of 0.040'' aluminium panel
i installed a coolant electric valve to stop the coolant flow to the heater core when i dont need it. but the valve is normaly open and the only time it is open is when i plug the car and when i cool the engine with the heater fan
1999 2000 BMW 323 325 328 330 XI I Heater Water Valve Ports 64118369805 | eBay
i installed a 850w tank type coolant heater because my 400w frost plug heater was not enought
http://www.fivestarmanufacturing.com...300&height=225
this is my new cooling setup
i bought the spare tire of my friend's crashed honda insight
and i tried it to see if it fits and it does
MPG=1 TIME=0
The Following 5 Users Say Thank You to echo-francis For This Useful Post:
BabyDiesel (11-17-2015), California98Civic (11-17-2015), Daox (11-16-2015), deejaaa (11-16-2015), j12piprius (11-16-2015)
Old 11-16-2015, 06:14 PM   #309 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
great looking mods. I want to relocate my battery to free up engine space.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 11-17-2015, 03:15 PM   #310 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Subscribed!
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
