Old 03-27-2018, 01:57 PM   #1 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 61.95 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
90 day: 38.2 mpg (US)
Wind or solar powered DRLs?
I originally was planning on adding DRLs to my Honda Civic, until I realized they created added drain on the alternator, resulting in slightly reduced fuel economy (I know it's splitting hairs, but still ).
But what about DRLs that are solar powered or powered by a turbine?
An example would be these: 8 LEDs Car DRL Daytime Running Light Use Wind Power
I'm sure they could be done as a DIY project if someone had the know-how too.
Any thoughts? Effect on FE or drag?
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 03-27-2018, 02:29 PM   #2 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Quirkily cool, but whats the benefit? Is there any light output on them or is just to say you have drl's (ex: nissan sentra low output drl on halogen headlights).
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 03-27-2018, 02:29 PM   #3 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Not an answer directly to your question, but, how much does it cost to replace a car from an accident?
To me, there is no compromise on safety equipment.
40w worth of drl's isn't going to break the bank. If you're concerned with alternator load, add a solar panel and charge controller. But, keep in mind those components are going to cost significantly more than you will save.
Old 03-27-2018, 02:51 PM   #4 (permalink)
DRL's will add a minuscule load, and if they are LED, it is negligible.
Old 03-27-2018, 02:53 PM   #5 (permalink)
90 day: 40.51 mpg (US)
Wind turbines collect energy by adding drag, and it will necessarily be larger than the energy savings of not running from the alternator.
EDIT: But those are really cool.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
NeilBlanchard (03-27-2018), samwichse (04-14-2018), Xist (04-14-2018)
Old 03-27-2018, 03:27 PM   #6 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Solar power on cars is pointless unless the purpose is to trickle charge the battery to keep it healthy. Wind would be even worse since you would only run it when parked, and that defeats the point of DRLs.
I'd throw some low wattage DRLs in, or disconnect them entirely. I find constant DRL replacement to be annoying, and I ride motorcycles, so the minute safety benefit of running them isn't worth it to me. I'll probably die of cardiovascular disease or cancer, just like everyone else.
Old 03-27-2018, 04:21 PM   #7 (permalink)
With the color of your car a couple of 4 in. strips of florescent orange tape on the bumper would be visible. We see fleet vehicles this way.
Old 03-27-2018, 05:18 PM   #8 (permalink)
This is sorta interesting. Using a windmill to charge the battery is a losing proposition, but adding drag to power the light directly might be a wash.
Now I'm wondering about anti-deer whistles.
https://jr-international.fr/repeller...m_english.html
"We're deeply sorry." -- Pfizer
Old 03-27-2018, 06:48 PM   #9 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
If you place the wind turbine in a location that needs less air flow then the parasitic loss would not off set the gane. like using the Electric fan sitting there windmilling as you go down the highway. Some kind of storage, (for when the fan is needed)
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 03-27-2018, 07:55 PM   #10 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
The minuscule amp draw from an LED running light could just about be offset by running the instrument panel lighting at a lower brightness (assuming that they’re incandescent lights)...
My current Ecotec project...
My last Ecotec project...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
NeilBlanchard (03-28-2018)
