Old 06-14-2011, 04:40 PM   #21 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
Yes its tapered, but optimal is between 10 and 15 degrees, the taper you have is a compromise between aero and cargo capacity.
Some of the more aero minded guys could probably fill you in more on what you can do.
Old 06-14-2011, 06:17 PM   #22 (permalink)
Enki's Avatar
Logs!
My logger doesn't have MPG logging capability, so I had to convert milligrams injected per cylinder to GPH to MPG. Math is below, logs are attached.
2,650,000 milligrams per gallon of gas
GPH = RPM * 2 * IA / 2650000 * 600
MPG = MPH / GPH
Edit: CSVs not allowed!?
Old 06-14-2011, 10:10 PM   #23 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
one thing about eco-modding.......................we don't tend to blow up motors from over reving them!!!!!
but we do use a crap load of coroplast!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-14-2011, 10:54 PM   #24 (permalink)
Originally Posted by Enki View Post
Logs!
No, a fuel log here on EM.
Old 06-15-2011, 01:04 AM   #25 (permalink)
apc
Mazda - '11 Mazda Mazda2 Touring
90 day: 38.93 mpg (US)
the engine can do it.
the chassis can do it.
the steering can not.
please do intense research into the steering modifications necessary for your vehicle to safely achieve the speeds you desire. stock will require hefty life insurance.
Old 06-15-2011, 01:09 AM   #26 (permalink)
Enki's Avatar
Oh? Right now it is gear limited (assuming 6500 redline) to 165 MPH. You're saying it can't handle another 35 for a short period of time in a straight line?
Old 06-15-2011, 01:12 AM   #27 (permalink)
apc
if you so much as twitch your thumb at 200mph with stock steering you will not be in a straight line.
Old 06-15-2011, 01:15 AM   #28 (permalink)
Enki's Avatar
Gotta love variable ratio steering boxes. On a wavy, very imperfect road it was stable up front but a little light in the back @ 140; a speed I've hit several times before running out of road.
Old 06-15-2011, 01:17 AM   #29 (permalink)
apc
ditto for my hondas. just don't ignore the steering.
Old 06-15-2011, 01:22 AM   #30 (permalink)
Enki's Avatar
I seriously hope you guys don't think I'm just going to build the monster and try for 200 on the first go... That would be pretty stupid on my part.
Thank you for your concern though, but I'm doing everything I can to factor in every single variable (including braking) and will probably be doing testing when fully built starting at 80 (which is easy and mostly legal) up to probably 140-150 on closed roads to 160+ at the event itself.
The first Texas mile you can't even run in the 200 class (I don't think) without some sort of proof of capability to handle it.
200 mph, mazda, shaved, speed
