08-24-2011, 09:00 PM
#51 (permalink)
Of course I can, but I would rather not go that route due to simplicity.
I'm well aware I can run auxiliary injectors, but at the boost/airflow levels I'm looking at only one small one would be needed, and it likely wouldn't evenly disperse due to the design of the stock manifold; aftermarket intakes also do not yet exist.
This build is already getting complex as it is; I would rather shy away from a tertiary fueling system that, if it ever went down, would cause my motor to pop.
Besides, direct injection is significantly more efficient than port injection, and I already plan on running WMI injection (but not tuning for it; it will just be another safety net for just in case, and will not be required to run the car safely).
01-10-2012, 06:19 AM
#52 (permalink)
Sorry, I've been out for a bit.
Using a diesel pump for direct injection won't work. Gas doesn't have enough lubricity and will shred the IP in short order.
So......... gonna sell that beat up, worthless, tiny K04? Or just, scrap it ?
The Following User Says Thank You to JasonG For This Useful Post:
01-10-2012, 11:09 AM
#53 (permalink)
I'm kind of surprised that there isn't some way to make it work with either coatings or oil or something; my high pressure pump internals (positive displacement type pump) has a diamond like coating which pretty much prevents anything from even wearing it a few microns thinner. Technology has come a long way, and I'd really like to believe there's an answer other than "no, you can't do that," even if it isn't monetarily feasible.
Oh, and the k04 is far from worthless, just can't hang on the topend is all. I was blowing the tires off with 20 psi on pure e85, but oil seepage was locking up the high pressure pump internals so I can only run 50/50 mix of e85 and 91 now (well, I COULD run pure e85, but I'd be rebuilding the high pressure pump every 20 miles or so).
Ethanol is a hell of a fuel, and I want to go back to using it, maybe even build a high-compression motor to leverage it better (for more power and mileage). The Mazda community I frequent will likely find that answer; just a matter of time.
01-11-2012, 06:25 AM
#54 (permalink)
If your IP can handle the volume (probable) are your injectors built like diesel injectors ?
Just wondering if the nozzles can be removed from the bodies and the holes enlarged, not with a drill but properly.
You will need to use the Gas bodies.
Hmmmm, got one that can be sent to a diesel injector shop for experimenting ?
01-11-2012, 10:52 AM
#55 (permalink)
Unfortunately, they are direct injection injectors, and the MFG saw fit to have them laser welded, which makes easy modification impossible. Only one set of enlarged injectors exists in the world, and the company that enlarged them said they wouldn't do another set ever again (due to cost). Everyone else on the platform (including myself) is stuck with stock injectors (which surprisingly are good for nearly double the stock power/output).
Other companies are looking towards releasing products which will allow us to increase the stock injector output and hopefully gain more flow, but that is all up in the air right now as we really don't even have a good way to log the relationship between injection window and injector action (other than wiring up an oscilloscope to the car, which has been done and will be done again).
Thanks for the thought though!
01-11-2012, 10:57 AM
#56 (permalink)
What are the typical points of failure in the 2.3 MZR?
I broke 170 in my Del Sol but melted a bearing, and couldn't save the block. Even with an adequately sized radiator and a higher flow oil pump, the stock internals weren't able to transfer heat away fast enough. I wonder if I had a longer tranny (and thus wasn't running 9,000rpm for an extended period under mild boost) if it would've been ok, since friction and thus heat go up with the square of the rpm.
Steering was also scary as hell, I wouldn't try it again without some serious work there.
01-11-2012, 11:06 AM
#57 (permalink)
Not sure about the 2.3 MZR but in the 2.3 DISI MZR the rods will bend somewhere near 30 psi of boost, assuming fueling is good. A lot of un/improperly tuned cars will vent the block (stock tune with heavy modifications like intake and downpipe).
As for output:
I later added 6 degrees of timing to this tune (as my targets were not hit) and managed another half pound of boost or so up top. Rated stock flywheel output is 260hp / 280tq; I've also since added a real downpipe to the car (which frees up a LOT of exhaust flow) and will be adding an intake manifold (which will correct the flow imbalance between inner/outer cylinders) along side an air/water intercooler (which will drastically improve flow and gain 2 psi or so efficiency from the turbo). That should put me somewhere near 320 hp / 400 tq, all said and done, with no modifications to the stock longblock.
01-11-2012, 03:50 PM
#58 (permalink)
These are VERY cool cars. If I had some change to spend on a good all around (fun and practicality) daily driver I'd be looking hard at one. I'll be watching this eagerly.
If you want some perhaps more accurate estimates of top speed, try Drag Race Analyzer. You can buy it online or download a free trial that gives you a week or two, just google it. The default simulation is of a 1/4 mile but there's a 1 mile, 1.33 mile, and 5-6 mile (bonneville?) setting too. You can input pretty complex stuff, like clutch specs, front and rear wheel weight and width, car height and width for aero purposes, etc.
I personally found that over a 2 mile flatout run, my mildly modified 85 Crown Victoria hit within 1mph of the speed the simulator suggested.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
The Following User Says Thank You to johnunit For This Useful Post:
01-11-2012, 03:57 PM
#59 (permalink)
I'll give it a shot, thanks!
Edit: The demo seems pretty useless unless you own a Shelby Mustang. I just can't see spending $80 on something I'll use for 10 minutes and shelve.
