Old 09-11-2011, 10:04 PM   #1 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Question Ecomodder Wiki alternator disable guide
Second rookie technical question of the day, sorry: I am trying to determine whether my 1998 stock Civic alternator is of the kind that the wiki describes as easy, or if it is of the sort that is more difficult and requires dis-assembly. I have been searching the PDF of the shop manual, but no luck (it might be there, I just have not found it). Does the 1998 Civic have an alternator that the ECU can disable with a signal when it is not needed? Thanks.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
Old 09-13-2011, 03:52 PM   #2 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
How many wires are going into the alternator?
I move at the speed of awesome.
The Following User Says Thank You to Phantom For This Useful Post:
California98Civic (09-13-2011)
Old 09-13-2011, 07:20 PM   #3 (permalink)
Thanks for catching this and replying. It looks like two, one the manual just labels a "WHT Wire" connecting to the "B-Terminal" and one that plugs in with a "4P Connector" ... good news?
Old 09-15-2011, 01:28 PM   #4 (permalink)
Phantom's Avatar
3800
I think that you can disable the alternator by disconnecting the wires I just found this post and it might help. Alternator Elimination on 1998 Civic EX
California98Civic (09-15-2011)
Old 09-15-2011, 02:41 PM   #5 (permalink)
Awesome. Wonder how I missed that thread when I searched. Wrong terms I guess. Thanks. Sent a PM hoping for an update. Printed the first post for a guide. I think I'll copy the strategy in my commute tomorrow.
I'll update when things mature more.
Old 09-15-2011, 03:58 PM   #6 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
I'm confused. What's the advantage of cutting the alternator if it's still hooked up? Or isn't it?
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 09-15-2011, 05:50 PM   #7 (permalink)
If the alternator is disconnected so that it does not power up to generate electricity, all that is left is for it to nearly freewheel, significantly reducing parasitic draw on the motor. But there's a catch... you will need to power up the battery again somehow. I will plug in the battery at night, and use a 1.5 amp on-board maintainer to keep its charge during my 22-24 mile round-trip daily commute. I don't know for sure how well it will work.
