Old 06-01-2011, 01:45 PM   #1 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Accord EX
HvyDrnkr - '93 Seville
Ecomodding a Classic / Antique Car or Truck
Here are the basic parameters:
Must have been built before 1974.
Bodystyle is open.
Modern updates are fine.
What would your choice be and why.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 06-01-2011, 02:33 PM   #2 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Actually I bought this a year ago, for $700 on craigslist. The sellers father started building it in the the early 1980s. It's a Fiberfab MiGi kit on a 1973 VW chassis (not super beetle). The original VW had just over 63k miles. He ran into a problem with the wiring and ended up cutting a bunch of the original wiring and giving up. He never finished the transmission tunnel work to reconnect the shifter, clutch and throttle cables. I welded in the missing part of the transmission tunnel from a donor car and got it so you could drive it, but it still needs wiring. I have a painless harness that came with the car for an extra $100. It has all of the top parts and interior parts except for a couple of pieces of carpet.
It has the original 1600 dual port Vw engine in it right now, but I was considering other options like a small diesel or even battery electric drive, if I could find some battery options that wouldn't weight 1000 pounds. Right now the front end is so light I can left one of the wheels off the ground. I may eventually make it a diesel hydraulic hybrid.
regards
Mech
Old 06-01-2011, 02:53 PM   #3 (permalink)
You got yerself a deal, that's a very nice looking car.
I remember the FiberFab products; used to have one of the biggest lines of kits available.
Old 06-01-2011, 03:07 PM   #4 (permalink)
Lotus Europa, with the engine & hybrid system from a 1st Gen Insight.
Or FTM I'd take the early '60s Austin-Healey Sprite I used to have, as it was :-)
Old 06-01-2011, 03:10 PM   #5 (permalink)
You must be short, because both of those cars I couldn't fit in!
Old 06-01-2011, 04:15 PM   #6 (permalink)
dude...wait...what?
Odin's Avatar
b2200 diesel - '84 b2200 D
Diesel Rx-7 - '82 Rx-7 GSL
merc 300d - '82 300d dt
72 Vega!
82 rx7 diesel
82 300d diesel
84 b2200 diesel
All veggie, all the time!
Old 06-01-2011, 09:22 PM   #7 (permalink)
Another Vega
Me too!
I also have a 1972 Vega. It's a hatchback GT coupe, bone stock, but unfortunately has the 2-speed air-cooled Powerglide, is geared very low and has a 2-BBl carb (not progressive).
I want to keep it as stock as possible, but maybe drop in a 200r4 to get OD and lockup, as well as a progressive carb.
The manual trannies were only 4-speed but 4th was a tall gear and they could get 32 mpg or so. The Powerglides could only get 18-19.
Mine was built for sale on the west coast and has the tilted windshield washer reservoir for the VertiTilt shipping scheme--but that's another story..
Oh, I forgot-it's not quite stock, it has a reman engine with steel sleeves.
Ray Mac
Old 06-01-2011, 09:30 PM   #8 (permalink)
Nope. 6 ft, and 190-200 lbs. Limber, though: been doing yoga and such since my teens. Had no problems with the Sprite: kept everything I owned in it for months when I was travelling around, and even slept in it, a few rainy nights.
Had one of those Vegas, too, back in the '70s. It's the reason I've never owned an American car since.
Old 06-01-2011, 09:35 PM   #9 (permalink)
I guess you and Jeremy Clarkson have the gift ( he's like 6'4 or 6'5 ).
Old 06-01-2011, 10:25 PM   #10 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
If I was shopping for a car then I would go for a classic Mini Cooper and get the kit to put a V-tec Honda Civic engine in it then go with the D15z1 engine.
Otherwise I think I'd go for a Honda Z600 coupe and figure out how to put fuel injection in it maybe even replace the large flat alternator that they have with a hail affect sensor and have it work as the starter as well for automatic start stop and mild hybrid.
3rd option would be a Seabring Vanguard Citi-car, the first year they built them was 1974 so it would just squeak in under the topic rules, install lithium batteries, a rear axle with a regular drive shaft so the motor didn't have to be unsprung and install a larger electric motor.
