Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-01-2010, 07:13 PM   #11 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Biggest thing one can do is remember to clean the coils regularly.
Old 09-01-2010, 07:32 PM   #12 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
I have a fridge like the one described in the article. It is a cheap chest freezer with this temperature controller added. I did not buy it to save energy, it was used for kegs of beer back when I was homebrewing. This type of chest freezer/temp controller is very common with homebrewers to allow fermentation to occur at exactly the right temperature. And to serve beer at exactly the right temperature.
I would use this type of chest freezer fridge again. It is far less expensive to purchase a cheap chest freezer plus a controller than a stand up fridge. And then your electric bills are lower as well.
If you were modding a chest freezer the way you plan to mod your stand up fridge, the chest freezer would just get that much more efficient. However instead of 0.1 kWh/day it might draw 0.08 kWh/day.
I never checked the amp draw on my chest freezer fridge.
The best advice I can give is to keep your fridge filled with beer.
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
wdb (10-07-2010)
Old 09-02-2010, 02:19 AM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Originally Posted by RobertSmalls View Post
Piwoslaw, you have an interesting fridge. I wonder, how much insulation does it have? My fridge's sidewalls including the steel outer and plastic inner shells are 4cm for the fridge, 5.5cm for the freezer.
Another thing I noticed is when my fridge turns on, it draws 680W / 6A
My refrigerator is an ARDO, model CO 2210SHX. Volume is 218 liters (7.7 cu.ft.) for the fridge and 83l (2.9cu.ft.) for the freezer. The refrigerator part's walls are 4.5cm thick, freezer 7.5cm, while the doors are 6.5cm and 9cm thick, respectively. It has a scroll type compressor which uses about 65W when on. No fans, no automatic defrost. We bought it in late 2007, today it costs the equivalent of $520, but is well worth every cent.
Piwoslaw's Peugeot 307sw modding thread
Old 09-02-2010, 08:30 PM   #14 (permalink)
Patrick's Avatar
Hot Tamale - '010 Prius III
Food for thought: Refrigerator Insulation - EcoRenovator
Old 09-03-2010, 10:41 AM   #15 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I would be disappointed with a 17% decrease in energy consumption. I can more than double insulation thickness across everything but the door, so I would hope to see a ~50% drop in energy consumption.
My fridge breathes in through the front and out through the back, so I'll have to leave the vent unobstructed, but I can insulate most of the back.
I can get R19 in fiberglass for $25-35. R20 in Polystyrene would be $170.
I was thinking about framing a 6' tall studwall in 2x4 and finishing it with 0.25" drywall and paint, but I'd probably be better served by building a freestanding plywood box around the fridge. Given the dimensions of my fridge (28"x26" plus a 4" thick enclosure), I can use two batts of 15" wide insulation on each side, and I'd only have to cut one batt lengthwise.
I would build the right and rear walls, insulate them, slide the fridge in, then install the left wall (the pretty one) and the top.
Now, how do I get three 4'x8's home in the Insight? I think I'll screw them together, then attach a caster and a handle and walk them home - 1.3mi. I'll just have to wait for a day without much wind.
Old 09-06-2010, 09:15 AM   #16 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
Wait for a windy day and put on your rollerblades...
Old 09-06-2010, 09:33 AM   #17 (permalink)
Patrick's Avatar
If your required width is low enough, have them cut the plywood at the home center (usually free), then load all the pieces in the hatch.
Old 09-06-2010, 11:04 AM   #18 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
For a walkable distance, it is easy to carry plywood on a bicycle. Lash a board to the handlebars so that it will support the sheets flat and stick out on one side enough to steer. Put most of the weight on the seat, and hold the sheets to balance and push the load. For drywall, a bit more wood for support might help.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
RobertSmalls (09-06-2010)
Old 10-07-2010, 12:22 PM   #19 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
Foam cushions (or barrow the cushions from your couch) between the insight and ply, and some lashing to keep them atop the car. for 1.3 miles you are likely not going to go fast enough for the aero penalty, nor to cause much lift.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
What is ecomodding? MetroMPG Forum News & Feedback 5 01-17-2012 08:08 PM
Ecomodding: there's more to it than just improving your fuel economy basjoos EcoModding Central 20 09-27-2010 09:18 PM
Accidentally improved KWH usage on fridge. brucey Saving@Home 3 09-28-2009 04:47 AM
Mass quantities of food in the fridge... Sean T. Saving@Home 8 10-29-2008 10:02 AM
