Old 01-19-2017, 01:52 PM   #181 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
haha, my friend said that I should screw a piece of wood behind the throttle so it only does 50mph
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 01-19-2017, 04:51 PM   #182 (permalink)
Originally Posted by Fingie View Post
a friggin' buggy would be nice, but we have a pretty cold climate sometimes.
I am looking at traditional ladas, anyhow.
I could fit a 1200L with magneto ignition, I could hand-crank it to start even if the battery's dead, due to the mechanic fuel pump
Have you ever tried to start a cold engine on the handle?
I had three Humber Sceptres (1725 H120 engine, 1725 standard engine (there's a 20hp difference)), all with a handle. If the engine was warm or hot, a little choke and it'd fire off the crank before it even did a revolution. Cold soaked on 9.0:1 compression not a chance, and this is summer in the UK.
I'd have probably broken something if I'd tried to cold crank that motor in the winter.
That said yours will probably be lower compression.. But still don't rate the chances, and have someone show you how to do it properly, if it kicks back you will be in a world of hurt, nursing a broken thumb.
Old 01-20-2017, 06:47 AM   #183 (permalink)
Fingie's Avatar
The Lada 1200 engine has about 8,5:1 compression if I recall
but War wagon will probably drive on for a while
Old 01-20-2017, 06:52 AM   #184 (permalink)
Fingie's Avatar
I think a WAI and aero mods could be the next thing to do.
I wonder if I should make a hand throttle.
Old 01-21-2017, 08:46 AM   #185 (permalink)
Fingie's Avatar
aww craps, I hit a block of ice on a trip yesterday and the exhaust broke.
But my consumption reduced. Was it THAT clogged?
Old 01-21-2017, 11:31 AM   #186 (permalink)
Either it was quite clogged or the catalyst is too restrictive.
BTW, why do you want a hand throttle? To use it like some sort of makeshift cruise-control? IIRC it's often found in agricultural machinery and some military vehicles.
Fingie (01-21-2017)
Old 01-21-2017, 12:56 PM   #187 (permalink)
Fingie's Avatar
some kind of cruise would be nice. maybe one that is good for DWL
Old 01-21-2017, 02:19 PM   #188 (permalink)
So, why would you actually want a hand throttle? BTW since it has EFI it probably doesn't have a provision for a choke lever like the old carburettor-fed engines, but you might find a way to work around it. Other possibility would be to do something inspired on those adaptations used by paraplegic drivers. Have you ever seen that French-style hand throttle controlled by a pair of levers assembled behind the steering wheel? Make one with provisions for a lock to set it at a predeterminated position and there you go...
Old 01-22-2017, 11:52 AM   #189 (permalink)
Fingie's Avatar
Also got my best winter MPG today, and I had 15kg of excess load+ my friend + I drove on lower-octane.
I could build a simple cruise.
Old 01-22-2017, 12:02 PM   #190 (permalink)
Fingie's Avatar
like this, but using really thin wire that snaps if you press down and release the pedal too violently?
guess that would make for the safety system
