Old 07-22-2013, 09:44 AM   #11 (permalink)
JB3
Work Van - '89 Chevrolet Astro
90 day: 28.43 mpg (US)
240D - '83 mercedes 240D
PS: your Beetle in the background of the first picture?
next door neighbor is a VW restoration guy. Thats his 1974 beetle DD, has one of those autostick contraptions for a transmission, making it of little value I guess to VW heads.
crazy setup, a clutchless stick shift with an electrically actuated solenoid that operates a torque converter for an automatic 3 speed transmission
Old 07-22-2013, 10:08 AM   #12 (permalink)
I have one of those- it's a head-scratcher for sure with all the disadvantages of manual and automatic transmissions combined into one super complex unit.
Old 07-22-2013, 12:04 PM   #13 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Awesome project. Clean work. You should have no problem achieving 35. Check out diesel Dave on this site. He can get tanks up into the high 40s low 50s. Utilizing engine off coasting (EOC) good luck with it!!
Burn lean and prosper \\ //
Old 07-22-2013, 12:24 PM   #14 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Awesome
Hi, and welcome.
I see you now have stats under your username. I think MetroMPG may have helped you out, I think he's the site owner/mod.
I know the aero on an Astro isn't great, but there's plenty of room for improvement. You could add a bellypan underneath, skirt those rear wheels, add an airdam up front, etc.
Go look at Aerohead's assorted posts, the guy is an aerodynamics whiz. And for inspiration, read up on Basjoos, who takes aerodynamic optimization to its ludicrous ideal...ludicrous, but profitable.
Subbed, if I can figure out which button to push.
Old 07-22-2013, 09:10 PM   #15 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Very neat! I'll bet you get some interesting looks from folks who are like..."Um, why does that Astro van sound like a diesel?"
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 07-23-2013, 01:50 AM   #16 (permalink)
Needless to say that I like this project, altough I'd rather use some Asian engine instead.
That transmission from Volkswagen was just a regular 3-speed non-synchronized manual, but had both a viscous torque converter and a dry clutch for the gear shifts. The clutch was only engaged when the driver touched the lever, with a photoelectric sensor like the one used in cars adapted to disabled drivers. There were also some versions which used the electric actuator similar to the one used in the cars fitted with the Saxomat automatic clutch, which had a centrifugal plate to keep the clutch depressed when idling and a vacuum-activated setup for the gear shifting, with an electric contact assembled at the shifter lever to release a vacuum solenoid.
Old 07-23-2013, 10:02 AM   #17 (permalink)
JB3
thanks for the tip! lots of amazing achievements on this forum, the engine off coasting is very interesting concept
Old 07-23-2013, 10:06 AM   #18 (permalink)
JB3
Originally Posted by elhigh View Post
Hi, and welcome.
thanks! good ideas, definitely a belly pan, and rear wheel skirts will do nothing to the daily usability of the van, while maybe improving economy
One thing id like to try and rig up long term is a ladder rack that either folds out, or is in some way aero. i only occasionally need to carry a ladder, but the bulky and exceedingly useful heavy racks on most work vans kill economy. If I can build something that can duplicate it but fold down behind some kind of wind fairing, that would be the best of both worlds for me
Old 07-23-2013, 10:10 AM   #19 (permalink)
JB3
so far ive had one guy jump when I fired it next to him, then come back and say "diesel?" Most people just think I have a major engine problem though.
I took it to get exhaust welding done at a hot rod place, and the consensus was "why would you do that?"
its amazing how many people equate added HP with positive, and lowered HP with negative.
Old 07-23-2013, 10:19 AM   #20 (permalink)
JB3
Frank Lee- I have one of those- it's a head-scratcher for sure with all the disadvantages of manual and automatic transmissions combined into one super complex unit.
I find it conceptually fascinating how they designed the transmission personally, thanks for this added description! Though it does seem to be a major piece of complexity. My neighbor has already rebuilt the think early this year, and its having problems again, requires constant attention.
Decided on the MB engine as I am very familiar with them, less so with asian plants, but there is a guy who put I believe a nissan 6cyl diesel and 5-speed in his astro as well. He reports excellent service.
Here is his thread on his build-
NissanDiesel :: View topic - Astro Van with LD28
and here is my build thread as well-
http://astrosafarivans.org/bb2/viewt...hp?f=72&t=8941
I would really love to compare the two eventually. His has been in service for years I believe, he's put a lot of miles on it
The Following User Says Thank You to JB3 For This Useful Post:
slowmover (07-23-2013)
