Old 08-19-2012, 07:42 PM   #1 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
metro body style (which generation has lower drag?)
Which Geo Metro body style is better for modding, 94 or 95? Which has lower drag?
-OR-
The 95 is safer.
Thanks
- Tony
Old 08-19-2012, 09:39 PM   #2 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
I think that the '94 has less drag. Notice how the rear of the '95 is raised like some kind of grasshopper!
The earlier '90's ones are the kings of mpg's for Geo's.
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 08-19-2012, 09:45 PM   #3 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Something like this:
- Tony
Old 08-20-2012, 08:17 AM   #4 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I am not sure if I like the GEO engines, only 77 mm stroke. My 1355cc honda had 82 mm stroke, the geo is not as torquey.
- Tony
Old 08-20-2012, 09:00 AM   #5 (permalink)
I think the first one as long as you drive in reverse all the time
Old 08-20-2012, 01:40 PM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
arcosine: FYI, the XFi camshaft is for - shifts torque band lower in the rev range. Not going plow fields with the Suzuki engine, but it helps some.
I have wondered if the 1st generation car has less frontal area than the 2nd. Don't know.... wait, now I know: Vehicle Coefficient of Drag List - EcoModder
The 2nd gen car apparently has 1 sq. ft. more frontal area.
Old 08-20-2012, 01:40 PM   #7 (permalink)
Something like that would be amazing. Do it!
Old 08-20-2012, 05:16 PM   #8 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
One problem would be seeing over the dash and steering wheel. The steering wheel can be shimmed lower down a bit.
I think red would be a good color. Almost looks like an insight. Iv'e never been good a body work, always turns out looking rough.
I wonder how much tail it should have.
Yes the third generation (95) has more head room. These metros always looked like they sit too high.
- Tony
Old 08-20-2012, 05:29 PM   #9 (permalink)
The second gen Metro has a lower drag in its sedan form than the Hatchback version! Thats kind of surprising when i first found out. But you have to decide if the Hatchback will be better to ecomod vs the Sedan version?
I try to be helpful. I'm not an expert.
Old 12-19-2012, 09:25 PM   #10 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
- Tony
