Old 01-03-2009, 05:16 AM   #1 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
Effect of ambient temperature on fuel tank volume
Hi folks,
I am about to log in my first results of a well-driven tank - I have got around 6 L/100 km, on a 1.5L 5 speed manual tranny Honda City. But when I get into the method of getting to my exact FE data, there is problem - as I think -
The SOP for finding FE is Tank up till clip off - reset trip meter - drive around till empty (of course almost empty) go back to the same pump, same orientation - tank up again till clip off - note amount of fuel pumped - note trip meter - divide fuel x 100 by trip meter reading to get L/100 km reading
But here, if there is significant temperature difference between when you tanked up earlier, and now, you will get less gas in the tank when filling up now (relatively colder ambient - shrinkage in the tank volume - less fuel to clip-off). The change in ambient temperature is because I filled my tank in Nov, and now it is almost Jan (quite a stretch in my refilling routine, because of hypermiling techniques, I should admit! )
Would that result in erroneously higher tank mileage? ( i think it will...) Should the SOP be modified? Any ways to calibrate out this error?
Wish you all a happy and fulfilling new year 2009!
PS: How can we prevent the spell check to highlight 'hypermiling' as a spelling mistake when posting? It is so embarrassing...
Old 01-03-2009, 09:32 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
We have spell check?
As to your fuel volume question, you could calculate the difference using this information, your tank volume, and the temperatures you experience:
Gasoline volume changes approximately 0.125% for every 1ºC change in temperature (0.058%/ºF) .
Source: Why have 9/10 cent gasoline pricing? - Arizona motorists deserve Automatic Temperature Compensation of gasoline at the pump!
Note that your specific results will be affected by whether or not your fuel is sold by volume (e.g. as in most of the USA) or by volume-corrected constant energy density (as in Canada).
Old 01-03-2009, 10:39 PM   #3 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 52.94 mpg (US)
The spell check is very likely part of your browser... all you need to do is right click the misspelled word (e.g. "hypermiler") and "Add to Dictionary"
Old 01-04-2009, 05:32 PM   #4 (permalink)
CobraBall's Avatar
Volume Correction Factors For Gasoline
File Type: jpg Volume Correction Factors For Gasoline.jpg (109.5 KB, 25 views)
Old 01-04-2009, 09:11 PM   #5 (permalink)
Great! So now I know that there is a way to correct for the density of the fuel.
But what about the tank volume changes going through that temperature difference?
Also does anybody on EM take these factors into account while fuel logging? Or it is "recognize the facts about density and tank volume changes - bemoan winter for low FE - put in figures from the pump and topup - carry on" business that is the norm?
Old 01-04-2009, 11:28 PM   #6 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
If the fuel in your tank is the same temperature as the fuel you're pumping into the tank (a huge - almost certainly unwarranted assumption) - and you know that temperature (it probably isn't air temperature, then you can use the chart CobraBall provided to make a calculation.
I certainly can't speak for everyone here, but I have better things to do with my time than attempt to correct for this factor.
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 03:29 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 10:24 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 06:31 PM
Smaller Fuel Tank steensn EcoModding Central 5 07-11-2008 02:09 PM
