Old 12-07-2009, 10:13 PM   #31 (permalink)
Deceptive - '98 Neon R/T
90 day: 44.38 mpg (US)
Originally Posted by Christ View Post
Yep, many manual transmissions call for ATF. I think most Ford transmissions actually call for it, but you can use engine oil as well.
many chrysler mtx's call for atf, but, and this is a big but, it is used to save money. The synchros will wear faster with it, and it will not shift as easy as the correct mopar fluid ($16 a quart) or mobil one 10w30 high mileage. Its very important to use mobil one 10w30 high mileage if you choose to use engine oil, especially in a neon, as the synchros are made of a material called fiberide, and according to oil analysis, only those 2 oils (the mopar stuff and mobil one stuff) have enough zdp to prevent premature wear to the synchros. Mobil one is 99% the same as the mopar stuff.
ive used both royal purple and penzoil synchromesh oils, and neither shifted as smooth as the correct mopar fluid or the mobil one oil
Old 12-07-2009, 10:17 PM   #32 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Cool. I'm not personally concerned about synchros, cuz I don't use the clutch anyway, but yeah.
Old 12-07-2009, 10:39 PM   #33 (permalink)
ya, i dont use them much either, 90% of my driving is freeway, but just wanted to make sure i posted in case anyone switches to atf then has problems. Its not really a immediate thing, more like a if you plan on putting 300,000 miles on the transmission thing
regular 75-90 gear oil on the other hand can destroy neon synchros in 5000 miles tho, thanks valvoline oil changers
Old 06-30-2010, 02:20 AM   #34 (permalink)
Send a message via AIM to bzipitidoo Send a message via Yahoo to bzipitidoo Send a message via Skype™ to bzipitidoo
Been using ATF in a 1967 4 speed manual Ford for years now. Originally had some heavy oil, might have been as much as 140W. It was getting very hard to shift into 2nd gear. Used to be fine, but then the shift to 2nd became stiff when the car was cold. Got worse, so that 2nd was hard to shift into when warmed up, and almost impossible when cold. Was taking serious force on the gear shift to get it in 2nd.
We switched to ATF, and 2nd gear has been fine ever since. Not sure how many miles we have put on it since switching, but at least 20k.
One thing about differential oil: has to be specially formulated for hypoid gears. Lot of pressure on those. ATF won't cut it.
Old 01-06-2011, 02:40 AM   #35 (permalink)
the green machine :P - '97 Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Does any1 know what the viscosity of lucas oil additive is because it says if u put all lucas in ur differential it will iliminate wear and if it's about a 65w when ur supposed to use 90w i'd say it's definently worth it????
Old 06-11-2011, 12:43 AM   #36 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
the brown goat - '03 impala base model
puddle jumper - '-1807 sidekick base model
energizer bunny - '86 trooper base model
Clifford the big red dog - '84 S-10 durango
cameo mobile - '91 trooper base or S model
road master - '86 pup base model
MPG+ pup - '81 pup DLX
this incorrect oil problem ive dealt with in Isuzu's too.
many fast lube places for some strange reason
have it in there computer that they take 80W-90 gear oil in the trans, when its really needs to be 5W-30 engine oil
in one to five years the bearings are shot
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 06-11-2011, 04:04 AM   #37 (permalink)
The high viscosity ensures transfer of lubricant throughout the gear train. This is necessary since the devices needing this heavy oil do not have pumps for transferring the oil with only a portion of the lowermost gears bathed in an oil sump.
