Old 01-02-2013, 06:53 PM   #1 (permalink)
rav
Gas HOG - '08 JEEP LIBERTY SPORT
effect of wheel offset on mpg
I am planning to swap the steel wheels on my Honda fit with a 55 mm offset with lightweight alloy wheels with a 45 mm offset. If i understand offset correctly, my wheel will stick out by about 10 mm from the fender. Will the gain in mpg by lighter wheels (low rolling resistance) be more then the additional drag caused by the wheels sticking out or I am just being paranoid and 10 mm will be barely anything at all.
Old 01-02-2013, 11:24 PM   #2 (permalink)
Sport Compact Driver
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.19 mpg (US)
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 30.44 mpg (US)
I dont think it will be a problem, 10mm is only a touch more than a 1/3rd of a inch. Aero shouldn't be affected esp if the rims and tires are still in the fenders.
Old 01-03-2013, 01:02 PM   #3 (permalink)
TheCav - '04 Chevy Cavalier LS
What about when you go over an unexpected bump, won't your tires wack the crap out the top of your fender? Don't think you'll avoid all bumps because all it takes ia one good wack to leave a pretty dent.
Old 01-03-2013, 03:49 PM   #4 (permalink)
mcrews's Avatar
The Q - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
Kia - '06 Kia Sportage EX
90 day: 23.63 mpg (US)
THe 10mm is not from the fender.
THe 10mm is added to the current outside edge of the tire. I dont think it will rub, but you should measure. Again, from the outside edge of the tire.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
Sven7 (01-04-2013)
Old 01-03-2013, 04:18 PM   #5 (permalink)
Jimmy - '00 GMC Jimmy SLT
90 day: 23.06 mpg (US)
The White Gnat - '99 Suzuki Swift
90 day: 54.17 mpg (US)
Whoa! Just gave me an idea: get offset wheels the OTHER direction for the rears & then can do a more "complete" fender skirt!!!
The Following User Says Thank You to wmjinman For This Useful Post:
Sven7 (01-04-2013)
Old 01-03-2013, 05:36 PM   #6 (permalink)
mcrews's Avatar
there you have it!
ECO MODS PERFORMED:
First: ScangaugeII
Old 01-04-2013, 12:44 PM   #7 (permalink)
PSmodder lurker
botsapper's Avatar
..so you can tuck in all the wheels inside all the skirts...
http://s.images.boldride.com/saab/19...197314-304.jpg
http://images.thetruthaboutcars.com/...97a-119008.jpg
Old 01-04-2013, 06:09 PM   #8 (permalink)
rally rally rally
Sven7's Avatar
Ren - '92 Honda Civic DX
90 day: 36.9 mpg (US)
Boo Radley - '65 Ford F100
crews is right.
Offset (wheel) - Wikipedia, the free encyclopedia
It should not make a discernible difference in fuel economy.
Commuting by Schwinn
Old 01-04-2013, 06:32 PM   #9 (permalink)
F150 - '94 Ford F150 XLT
The Bonneville speed guys carefully place the wheel offset for minimum drag. That said, I don't know if you can do it by eyeball, and furthermore at highway speeds I doubt it makes a detectable difference. But if you are going whole hog, it should be investigated via tuft tests or ?
Old 01-04-2013, 06:37 PM   #10 (permalink)
rally rally rally
Sven7's Avatar
Or go to one of those speed runs at airports and do coast-down testing from 100mph. You'd need to have the same tires on each set of wheels, though, for consistency.
alloy, drag, offset, steel
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
