Old 12-04-2009, 11:40 PM   #1 (permalink)
Avant - '99 A4 Avant
90 day: 26.94 mpg (US)
Efficiency increase with a warmer engine? (195F vs 165F)
Had some work done on the car this week (t-belt, water pump, t-stat, and other stuff). With the change of the thermostat came a change in the operating temperature of the car.
Looking back I should have realized that the car was running cool, especially the last couple weeks since I got the ScanGauge and had a digital temp reading. Most likely the t-stat was opening way too early, or even staying open slightly. The cars 'normal' operating temp was ~165F, and would cool down when in DFCO, sometimes quite noticeably (down to 120F on one long downhill in 5th gear). Thus it was still flowing coolant through the radiator and cooling it even when then there was no extra heat load.
With the new thermostat I'm now seeing the factory gauge "where it should be", and the digital gauge is telling me ~195F (its a 188F t-stat, tested and it does open right at that). Also the engine temp is steady now on a long deceleration with fuel cutoff.
So what I'm wondering, is there some efficiency gained now that the engine is running 30F warmer than it used to? I'd say the oil is slightly thinner at the higher temps, but that's questionable with the viscosity modifiers. What about the cylinders, any chance of better combustion with the warmer engine block?
Old 12-05-2009, 12:20 AM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Absolutely! You may have not been getting the fuel injection controller out of the enriched mode, and more of the fuel will be vaporized.
Old 12-05-2009, 01:53 AM   #3 (permalink)
pgfpro's Avatar
Here's a coolant temperature correction map off my Haltech.
As you can see when the engines coolant is cooler there is more of a increase based in % added to the pulse width of the injectors.
Factory ecu's will even have more of a correction all the way up to normal operating temperatures.
The Following User Says Thank You to pgfpro For This Useful Post:
MetroMPG (12-06-2009)
Old 12-07-2009, 10:31 AM   #4 (permalink)
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
Your brake thermal efficiency increases with increased engine operating temperature. The theoretical Otto cycle efficiency is always higher than actual thermal efficiency due to the adiabatic assumption in the theory not applying in the real world. The hotter your engine runs, the less heat of combustion is lost to the block walls, and the closer you approximate the adiabatic (zero heat transfer) ideal.
Old 12-08-2009, 11:21 PM   #5 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 47.02 mpg (US)
"In theory there is no difference between theory and practice. In practice there is."
Don't remember where I got the quote but your last post, I think, said the same thing.
Old 12-08-2009, 11:38 PM   #6 (permalink)
Agreed. I'll bet your old thermo wasn't opening fully, hence the reduced operating temp. Thermos are a PITA in that they can fail partially and be problematic in operating only marginally. You probably didn't have much heat from the heater in the interior either, if you noticed.
Old 12-09-2009, 09:35 PM   #7 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...would co$t more, but an electronic thermostat (controlled by ECU) would get the job done much better! (servo-mechanical flow control or electric pump control)
...it could hold the flow totally off until it's actually needed, and then only pump or pass just enough coolant to keep thermal equilibrium.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 12-10-2009, 09:36 AM   #8 (permalink)
Mechanical Engineer
It's been a long time, but I remember pan-testing a thermostat on the stove. I seriously doubt you would be able to detect any cooling performance increase from a servo-actuated thermostat as I recall the spring thermostat nearly jumped out of the pan when it opened up, and they continuously adjust pretty well if temperature drops too low. They are fast-opening on warmup and maintain low enough flow to stay at their design temperature pretty well. An old, tried-and-true design not likely to be replaced until our vehicles no longer need liquid cooling systems.
Old 12-10-2009, 09:49 AM   #9 (permalink)
...beats walking...
...agreed, not a co$t-effective replacement today, but when electric water pumps eventually become more common, under ECU control, it would certainly be more energy efficient to modulate total flow and use energy pumping coolant around only when you really have to.
...instead of "pumping" all the time and then apply "throttling" on top of that.
Old 12-10-2009, 10:03 AM   #10 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
If the electric water pump is ECU controlled, why would you need a t-stat at all?
I mean, the ECU could just shut off the pump and monitor temps until the pump needed to move the hot coolant.
"Ώʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux κtre heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 358 01-31-2012 06:54 AM
Article: adding a turbo to improve efficiency MetroMPG EcoModding Central 106 10-23-2011 01:00 PM
News: Denver launches "Driving change" program to increase efficiency MetroMPG Hypermiling / EcoDriver's Ed 4 03-13-2008 04:18 PM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 08:06 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
