Old 08-29-2008, 04:02 PM   #11 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '010 Agility 125
Ah, interesting. I would probably have to cut an access hatch (I don't think Hondas have the removable 5th gear endcap like some Saturns and other cars have.)
This would probably be easiest on a RWD vehicle, as you could easily splice in a motor anywhere in the driveline. The reason I was looking for a engine-belted solution is because it would just need a bracket and pulley.
Old 08-30-2008, 02:49 PM   #12 (permalink)
weight penalty
Originally Posted by trikkonceptz View Post
I know this topic has been discussed here many times, however I have a question related to it.
Would the added weight of the components (Engine, bracketry,controller & batteries) offset the benefits of being able to power yourself up to 40mph?
I have been planning this mod as the prelude to building an electric vehicle, but considering the modifications to the Vibe I am wondering if it really would be worth while.
I may just skip plan A and go straight to plan B (Electric Car).
According to the big-dogs,a 10 % weight gain would cost you about 3.7 % mpg.You could weigh out the potential benefits of the 5th wheel against the increased mass.If you show in the black vs red ink,then it makes sense to do it,should the cost,time and trouble warrant it.It would be an interesting experiment.
Old 08-30-2008, 07:09 PM   #13 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
how about...
An etek motor bolted where your starter is and drive the right axle directly from the etek? This will drive the left axle through the diff.
While I was in WV with CoyoteX we discussed this type of setup when we were looking at the motor/trans sitting on the ground before the install.
You could run the etek through one of the re-gen controllers and use it to charge batteries on the highway while you ran off the ICE and use the batteries for driving of the etek in town,
Attaching to the axle directly allows you to dis-engage the ICE form the equation by putting the trans in Neutral.
The etek then becomes your starter, you get rolling on battery and bump start when you need the ICE.
When I get my millions I will look into putting together this type of system as a sort of
Po' Man Hybrid (tm)
Schultz $.02
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
Electric fifth wheel (DIY through the road parallel hybrid) friedlbug Hybrids 21 01-06-2010 05:54 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Electric 5th Wheel trikkonceptz EcoModding Central 6 05-27-2008 12:58 AM
