__________________ As I watch the old man walk on the sidewalk below my window, I think "Some day old man, I will be like you. So why not give me your coat?" Then I go downstairs to get his coat, but he's gone. Hey, maybe he was Zorro.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
400 amp controller installed. Here's how it looks...
0-50 km/h in ...
36 seconds with the old 225 A controller 25 seconds with 300 A 21 seconds with 400 A
A lot of the total time has to do with technique. I just started out in 2nd gear with the 400A controller since it won't even pull 400A from a stop in 1st.
Also it's quite a bit cooler today, and the car wasn't limbered up.
Didn't do a top speed run.
Now that you have the 400A controller you might want to bid on one of these.
No I believe you, just show me a source please
Let's put the new power in context: one time you don't want to hypermile/hyperwatt is when you're bringing home the take-out Chinese food. I used the ForkenSwift to get it this evening and it was still steaming hot when I got home.
__________________ Latest project: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Latest test: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - fuel efficiency info for Geo Metro owners To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - electric car conversion on a beer budget
So to show Ivan the POWAH of the 400A controller, I just left 2 little stripes in his driveway.
OK, so it's a gravel driveway.
But the first controller wouldn't even do that. I had trouble spinning the tires in snow!
Well, yes. Also I suspect the 225A has different logic than the 400A.
Well, the 400A unit has a user-settable acceleration ramp (via a pot), and a couple of other adjustments. Haven't played with them yet.
I always found the 225A acceleration ramp to be sluggish - it definitely wouldn't give you 225A immediately from a standstill (though you could get it under way). And it would bog down in thick snow at low speeds (ie come to a stop, with no amps showing on the meter).
