Old 10-24-2010, 05:17 PM   #21 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Maybe a bigger reservoir or a cap/reservoir thing could be fabbed up to contain the displaced fluid. Or perhaps it can be run a bit low intentionally so that it is less likely to puke up. Or probably being very vigilant about not making large lock-to-lock maneuvers when the power is "off" would take care of it.
Old 10-24-2010, 06:38 PM   #22 (permalink)
Bus - '94 School Bus huge
Stupid - '01 Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Superhawk
All I know is that when we push a ford out or back in to the shop it sprays everywhere. It doesnt take long for it to overcome the airspace in the reservoir.
Old 10-24-2010, 06:46 PM   #23 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
ah well, keep the level under observation and see if it stabilizes I guess.
Old 10-25-2010, 01:05 PM   #24 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Flyby post:
Some sports car company was making speed sensitive steering, but i don't remember who.
Guess they were being ecco and didn't know it !
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-12-2010, 12:14 AM   #25 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Impreza Outback Sport
90 day: 27.81 mpg (US)
It would be rather simple to rig up a limit switch so that it turned on after 10deg of turning, but that may kill you. Also some switches at the base of the shifter could make it be on for 1, R and maybe 2, but it would shut down between gears. With big bag of switches and a micro possessor you could rig up something almost safe (until a switch breaks).
I just hope a deer (or a kid) doesn't jump out in front of you when you have it off, and your going slow (but not slow enough to stop).
Originally Posted by JasonG View Post
Flyby post:
I think most car companies are doing that now, at least on some models. My girlfriend's '89 Toyota Cressada has it (though it was one of the first cars to offer it), every Subaru 2000 or newer has is. It's not rigged up the same way, and may not help over all eff at all, as far as I know it was only advertised as a "better feel for the road" type thing.
Redneck Repair forum
Old 11-23-2010, 07:38 PM   #26 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by RobertSmalls View Post
If you want to convert to electrohydraulic power steering, you could source a 12V GM power steering pump, which I'm pretty sure are not just a figment of my imagination. But it wouldn't really solve the problem unless it has a good controller that shuts the motor off when you're not steering.
VW has a speed sensitive steering of sorts, and I know you can buy an electric ps pump for Toyota MR2s and for Ford Escort Hybrids.
I have been researching a similar idea, but using an electric motor to drive the ps pump via a belt. Grand plans include a shut-off at approx 25 mph which should help cut fuel use...
Old 11-24-2010, 03:17 AM   #27 (permalink)
Random INput.....
BMW and others are using full electric power steering with no hydraulics.
I think the gear selected assist is the best, You already have the reverse light switch just attach a second switch for 1st gear, even an automatic would work with it... You could add a RPM switch to prevent it from activating if the RPM's were too high to save the clutch.
A dirt track pump would be a better choice than the ford or use a Jeep wrangler pump, it has a remote tank as well and its tiny... They also sell very lightweight and strong steering racks.
Dodge trucks have a electric clutch on the fan.... And its whomper...
Dave
If it has a motor its worth playing with.......
Old 11-24-2010, 06:03 AM   #28 (permalink)
dcb
needs more cowbell
dcb's Avatar
Just swap in a manual box before jerry calls you a baby killer...
Old 02-23-2012, 09:53 PM   #29 (permalink)
4ringcircus's Avatar
Ford Ranger - '97 Ranger XLT 4x4
Update. Been driving the truck for the last year and a half and it has been trouble free. I use it when parking, turning street corners, and clover leafs. I have not added power steering fluid; simply turning it on with some regularity keeps it from overflowing.
I would not recommend fancy electronics to automate turning it on or off. The 'power assist' turns on and off instantly, and it comes down to safety: I need to know I am turning it on or off as the effort required to steer is suddenly and drastically different.
My best tank of gas was 24 mpg's... on a 4x4 extended cab!
Old 02-24-2012, 11:16 AM   #30 (permalink)
Elle - '010 Element SC
push button switch on the steering wheel?
diy, electric clutch, electric pulley, power steering
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 66 03-28-2012 08:06 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 123 07-25-2011 09:24 PM
Ontario suspends registrations of converted electric vehicles (update: ban lifted) MetroMPG Fossil Fuel Free 45 09-25-2010 05:21 PM
My wife doesn't mind not having power steering in the tank!!!!! IsaacCarlson Success Stories 21 10-19-2009 11:50 AM
