Old 08-02-2013, 02:31 PM   #61 (permalink)
Originally Posted by justme1969 View Post
It would be awesome for a throttle sensitive switch mabe disconnect @ 1800 rpm? Not sure application is key but a toggle switch to flip on when parking would be Jazzy for my app.
You could do this very easy with a spark ignition car.
You can buy MSD brand RPM activated switches. They are no more than a set of electronics that uses an ignition system signal to figure RPMs, then it turns a relay on or off at depending on what RPM its set for.
Their main use is powering nitrous oxide and fuel solenoids so they can handle any kind of P/S clutch you might want to use.
I will tell you how I would wire it up.
First of all I would have a toggle switch that I could flip on for use in parking lot situations.
Then I would have it wired into the reverse light and brake system so any time I backup or apply the breaks I have P/S.
I would also add a time delay that will power up the clutch for the first minute or so after I turn the key on, that will just to get out of the drive way and on the road.
Then lastly I would also add a little indicator light that will turn on when the P/S clutch circuit goes hot.
Old 08-02-2013, 02:33 PM   #62 (permalink)
Ha ha. Or just disable it.
Old 08-02-2013, 08:01 PM   #63 (permalink)
Function over form!
vrmilionzx's Avatar
S14 - '95 Nissan 240sx se
Sports Cars
90 day: 19.89 mpg (US)
S13 - '93 Nissan 240sx base
Sports Cars
90 day: 25.42 mpg (US)
Send a message via AIM to vrmilionzx
Originally Posted by oldtamiyaphile View Post
Good luck performing a swerve and recover manouver at speed w/o PS.
I've had an MR2 electric pump (on a manual switch) in my 93 240sx for well over a year now, and swerving works just fine at speed (occurs regularly in LA - people love to try hitting me).
I'm kind of surprised that nobody has mentioned that additional benefit of disabling your PS - good workout! I've definitely gotten stronger as a result
Old 08-02-2013, 11:17 PM   #64 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
The "Sport Coupe" Tempo.
I'm always coupling/decoupling from trailers with the F150 so the power steering is going to stay on that one. Plus I don't think it'll make a noticeable fe change on it.
Got a Tracer I'd like to hit 50mpg with; best fe was 42 so I'll have to see what it'll take to bypass the power steering on that one.
Thinking back now, I had a 91 Jetta that had power steering, and a 1.8L with 9.6:1 compression...and I couldn't understand why it would not match or beat my older 84 Jetta's mpg, which also had a 1.8L but with 8.5:1 CR. True the older car was lighter...but it didn't have PS either. I cut the PS belt off the 91 and voila! Matched the older car (another 1 mpg, maybe 1.5. Memory is fuzzy now). Steering felt the same as the older car--same size wheels/tires. 185/60R14.
diy, electric clutch, electric pulley, power steering
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 92 01-27-2017 03:58 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Can I use a GENERATOR to power an Electric car directly? Nerys Fossil Fuel Free 128 10-01-2012 01:24 AM
Ontario suspends registrations of converted electric vehicles (update: ban lifted) MetroMPG Fossil Fuel Free 45 09-25-2010 05:21 PM
My wife doesn't mind not having power steering in the tank!!!!! IsaacCarlson Success Stories 21 10-19-2009 11:50 AM
