Old 07-22-2011, 10:24 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
"Electric" dragster, 0-213mph in 2.5 seconds
Waterthunder, add 28 gallons of water and plug it in for 40 minutes (@ 100kw).
214 mph in 2.5 sec: water-powered record stands the test of time
(Why not consider solar or wood power? with a looong time between heats of course)
0-200mph in 2.5 seconds is on par with top fuel dragsters.
The Following 2 Users Say Thank You to dcb For This Useful Post:
Cd (07-24-2011), MorphDaCivic (07-27-2011)
Old 07-22-2011, 11:12 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...'cuz, when you're "...in a hurry..." you're in a HURRY!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 07-24-2011, 08:15 PM   #3 (permalink)
that looks like a bit of fun to drive
Old 07-24-2011, 10:52 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for posting. That's completely awesome.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 07-26-2011, 11:58 AM   #5 (permalink)
Originally Posted by dcb View Post
...214 mph in 2.5 sec...
But it ONLY goes for 2.5 seconds :-( Though I do suppose you can glide for a bit...
Old 07-26-2011, 12:50 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
Well nhra keeps clipping down 1/4 miles to like 1000 feet, and there are lots of 1/8 mile tracks, so maybe the two will meet someday
You could carry more water, but you have to eject it at a faster rate to keep the same acceleration curve (and put more energy into the heating of the water), this may be the optimal size, or there may be diminishing returns worth pursuing. It IS rocket science
wanted to capture some notes from Waterthunder
"..steam... will reach a velocity of about 1500 feet per second"
"a lightweight tank designed for low pressure will perform as well as a heavy tank designed for high pressure"
"the quantity of water filled in the tank will determine the maximum speed that can be reached"
"The nozzle should first have a converging section then a diverging one, with the exit diameter two to three times the smallest (throat) diameter. The nozzle should diverge at a total cone angle of not over 25 degrees. The convergent section may be rounded to a radius about equal to the throat diameter"
