Old 03-30-2011, 01:10 PM   #1 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 CJ7
Electric fan mod not going so good
So I have been trying to install an electric fan into my old CJ-7 for a while now. I picked up a couple of Ford Taurus 2 speed fans from a junk yard. They work fine, but wont fit between the engine and the radiator, the water pump rubs the motor of the fan. I tried figuring out a way to mount it to the front, the motor is reversable, but the fan does not work so well in reverse.
Next trip to the junk yard I got a fan from a BMW that mounts up front, but the motor is dead.
Tried putting the BMW fan onto the Taurus motor, and made a mess out of it. It came out badly out of ballance.
Looks like its time to order a fan and mounting kit.
Old 03-30-2011, 01:47 PM   #2 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
+1 for trying
Actually, you tried twice, so +2
Piwoslaw's Peugeot 307sw modding thread
Old 03-30-2011, 02:43 PM   #3 (permalink)
kir_kenix
kir_kenix's Avatar
1997 Chevy s10 - '97 S10 WT
Pickups
90 day: 27.79 mpg (US)
1997 Ford Escort - '97 Escort LX
Team Ford
I've also run into this. Shaft diameter being the same, motor still runs out of balance. My only guess is that some motors must use the fan blades as a dampner/balancer and some motors must have precision ground shaft/inline bearing & bushing.
Then again, some electric fans seem out of balance from the factory (ever looked at a dodge minivan fan while running? wobbly as heck...don't know how they manage to not make a racket).
Old 04-01-2011, 01:11 PM   #4 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
Take the ford fan drill all the way through the mounting point to flip the fan in the other direction so it is not spinning in reverse and use a nut and some JB weld to hold it on.
I move at the speed of awesome.
Old 04-01-2011, 02:26 PM   #5 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
^ Either that, or find a way to move the rad forward a hair, or trim the shroud to get the blades closer to the rad (giving more clearance to the water pump).
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 04-01-2011, 04:20 PM   #6 (permalink)
Phantom's Avatar
3800
Depending on how much room there is and how the radiator is mounted you could just stack some washers and use a longer bolt to move it forward
Old 04-01-2011, 09:18 PM   #7 (permalink)
TheEnemy's Avatar
I was thinking about this solution already.
Spacers/washers would move the radiator closer to the engine.
Old 04-02-2011, 06:19 AM   #8 (permalink)
eco fighter - '92 civic hatch cx
if not ive bought several hayden fans for old chevy 4x4 builds from oreillys. they work great and not that expensive. and they can be made a pusher or puller by just flipping the blade around. be careful they are come out of the box a pusher. found that out the hard way couple of years ago. comes in many sizes. they make controllers too.
