EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Electric Mini. (https://ecomodder.com/forum/showthread.php/electric-mini-35411.html)
JockoT 07-25-2017 10:49 AM
Electric Mini.
BMW have today announced that the will build a fully electric Mini at their Cowley plant, in Oxford, here in the UK. Production will begin in 2019.
https://ichef-1.bbci.co.uk/news/660/...75321_mini.jpg
BMW says the economic case for building the electric mini in Oxford is compelling, and it's easy to see why.
This is not a brand new car, redesigned from the ground up. It's a Mini, a 3-door hatchback, which will in many ways be identical to the cars already being built at the Cowley plant.
The drivetrain, which includes the motor, gearbox and battery pack - will be assembled in Germany, and fixed to the rest of the car in the factory.
NeilBlanchard 07-25-2017 11:59 AM
Will it have a backseat?
JockoT 07-25-2017 01:15 PM
https://encrypted-tbn0.gstatic.com/i...IfeaSJYA4UJfdQ
freebeard 08-09-2017 02:07 PM
EV-converting an existing platform is why the legacy manufacturers will never catch Tesla.
ksa8907 08-09-2017 03:08 PM
Its cheaper, but obviously you guve up some optimization. Which also means it will be an inferior product.
cRiPpLe_rOoStEr 08-10-2017 04:44 AM
I might have to disagree on that, using a platform from an ICE-powered car may not lead an EV to become "inferior".
NeilBlanchard 08-10-2017 09:58 AM
BMW is apparently going to be building a Mini-e in the near future.
freebeard 08-10-2017 10:57 AM
Not a strong disagreement then?
There are significant architectural differences to be reconciled.
ksa8907 08-10-2017 11:07 AM
Yes, and getting shot in the head may not kill a person.
cRiPpLe_rOoStEr 08-12-2017 04:41 AM
There were some people who survived after getting shot in the head, but that's a different matter anyway. But when it comes to repurposing a conventional platform into an EV, there are many aspects that should be taken in consideration. Sure a dedicated platform could address issues such as the center of gravity and weight bias, but it's still not impossible to get good results with a setup based on an off-the-shelf platform. There are also people who look at an EV due to tax incentives, but don't want all the attention that an unconventionally-designed car would get. But anyway, if I were going to convert a conventional car to electric I'd be mostly inclined to make it RWD. The compactness of either a rear motor assembly similar to the one fitted to the rear axle of Toyota and Lexus hybrid crossover SUVs seems to be easily adaptable to most applications and quite space-saving, leading to more freedom to either arrange the battery packs in a way that would become less harmful for the handling or to clear enough to allow an extra luggage compartment. So, since an EV built around an already-existing platform can be as functional as one built into a dedicated-EV platform, it would not be "inferior" at all.
