Old 01-20-2012, 06:32 AM   #271 (permalink)
I was considering getting a 24V 6-7-8kW modell from a scrapyard and drive it on 12V only. For my goals a continous 1-1.5 kW would be acceptable, with few seconds / half a minute peak power of 2 - 2.5kW.
I know even though they might overheat in no time... Well, it's an option to try anyway. If somebody has a huge truck starter at home, they could hook it up on a car battery and see what happens.
(I saw a small car conversion in Hungary done by a group of students. They got a rally small Fiat 126 "car" and somehow they acquired a pair of Ilyushin airplane starter motor. That runs ok. but of course that motor might be a completely different construction.)
Old 01-26-2012, 12:54 PM   #272 (permalink)
Actually a 2kw 24v oil pump motor surfaced on the local ebay-ish website.
I wonder if it would be able to propel me with about 70km/h?
the thing is, that I live just by an expressway. On that road the office is about 15 minutes away, while If I do the same distance throught the city it takes about 30-40 minutes with lots of redlights, crossings....
So If the thing would be capable of giving me 70km/h than I'd be able to use that expressway.... I could not find information what peak I could squezee out of suck a pump-motor.
Old 01-26-2012, 01:16 PM   #273 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
24v 2kW means about 83 amps continuous, at whatever voltage you pretty much want to use. How much does it weigh? That sometimes gives an idea of how much thermal mass it has, so it can take higher currents longer. I think you could do 70km/hr easily with the right gearing.
signature goes here.
Old 01-27-2012, 08:26 AM   #274 (permalink)
the motor is still on internet i do not owe it. After some thinking I decided that for start I will go for an electric bicycle. Mostly to experience how much energy it will really take to roll from A-B, and also to convice my other half that putting money into a bit more powerful vehicle will envetually return.
So for now I'm looking for a power steering motor (anyone has an idea what would be it's usual power and RPM??). I already found batteries that should do the trick, and the costs are not that alarimngly high. It will be an experiment.
later I beleive I'll get a used palet-lift. (or what's the name of those little carts, people use in department stores to move the stuff around) This way I'll be able to lay my hands on batteries, centrolling electrics and a 2kw-ish pump motor. I saw a 4.5kw pump motor on internet, but to feed it on my daily 30km round trip, it would need a huge battery pack. But if I'll be lucky and I find a bigger palet-mover... (i had some luck working with one, which was a normal forklift, with the operator walking behind. that might have a bigger motor in it... 3kw would be great. )
Old 01-27-2012, 10:57 AM   #275 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
Building your own electric bicycle is a great project. It will really help you get some experience on working on electric vehicles, and have a lower budget as well.
Another advantage of an electric bicycle is that they are typically designed so that the pedals still work. So, technically, it's a hybrid! You can always pedal more to extend your range. Or, it there is ever a problem with the electric system, you have the pedals to fall back on. If all else fails, it's still easier to push than a motorcycle!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-27-2012, 11:17 AM   #276 (permalink)
thanks!
my original idea was to get a car power steering motor (I read an article about an electric bike like that with really simple control electrics) adn use that.
However I have the problem of the gearing.
I'd put a second chain on the left side and have a chain to the motor/gears.
i could not find a "gearbox" which would suit me.
there is a company importing motors, and they do sell motors with gear reduction, but they are costy and I'd rather trust in a motor from an Opel or Toyota... All their motors are either on 24-36V, or below 250W. I found batteries for good price. would be ideal for 12/24v batt rack, and I'd not need a third battery for a 36V system. I hope it makes sense.
All comes nicely together apart from the gears...
Old 01-27-2012, 11:24 AM   #277 (permalink)
I actually found an 80 teeth sprocket on a website. It would give me around 1:8 ratio... i need to know how much a power steering motor would turn...?
any idea? I could not find any specifications
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
What's your best motorcycle MPG? MetroMPG Motorcycles / Scooters 345 10-12-2011 11:00 AM
Dirt-E Bike (Kawasaki KE-175 Electric Conversion) FrankG Fossil Fuel Free 10 10-08-2008 06:38 PM
Motorcycle fuel economy champ's advice for efficient cross-country touring... MetroMPG Motorcycles / Scooters 6 01-31-2008 02:38 AM
Video: sweet electric Yaris is driving! (Conversion) MetroMPG Fossil Fuel Free 1 12-15-2007 02:11 PM
