Old 03-23-2008, 08:56 PM   #31 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Any plans to shoot a vid showing off the bike this spring? Hmm? :P
Old 03-23-2008, 09:15 PM   #32 (permalink)
Where is your speedo getting its reading from?
S.
Old 03-23-2008, 09:40 PM   #33 (permalink)
Fossil-Fuel Optional
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 26.95 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
I am planning on taking the cycle to the Milwaukee Hybrid Group meeting in April.
That might be a great place to shoot video. Otherwise at least if we get some good weather first, then I can shoot some video.
The cycle is using the original speedometer. It has a cable that runs to a connection directly on the front wheel hub.
Old 03-23-2008, 11:13 PM   #34 (permalink)
Ryland's Avatar
Tomos Arrow - '05 Arrow ST
90 day: 101.68 mpg (US)
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
often times the speedo does what you are talking about simply because it's sticking, if you can find some spray graphite, you should be able to fix it by pulling the speedometers apart just enough to get the spray can straw in there, spray around a bit, and close it up, they are of course designed to keep it sealed so people can role it back to reduce the number of logged miles, but spray graphite is amazing stuff, it's mixed with alcohol so it dries to a nice slippery film as you don't want anything that will attract dust.
I had my scooter out Thursday for a while, filled it up with .41 gallons and put a wire basket on the rear rack, looks much better then a milk crate and holds stuff nearly as well.
Old 03-24-2008, 06:35 PM   #35 (permalink)
Another good way to lube your cables is to unhook the top end of the cable, poke it through a ziplock bag, tape up around the hole for no leaks, put some oil into the bag, set it & forget it!
The oil will slowly seep through the line. When doing your brake lines you can pump the brake a bit too.
S.
Old 03-26-2008, 07:51 PM   #36 (permalink)
bennelson's Avatar
S10 - '95 S10
Here ya go. First video. Nothing much, just shows how the contactor I added works.
Someday I will get around to making a real video
[YOUTUBE]
Old 03-26-2008, 08:04 PM   #37 (permalink)
40 mph - Someday
TomEV's Avatar
Citicar - '76 Citicar
90 day: 151.7 mpg (US)
Your odometer should be working as it is connected directly to the speedo cable by gears. The speed needle can stick - typically the only thing dragging it forward is a magnet at the end of the cable that 'pulls' a metal cup attached to the needle inside the case. Sometimes they stick due to old grease that builds up a small speed bump. Should be easy to clean/relube if you can get the case open.
Old 03-26-2008, 08:10 PM   #38 (permalink)
Silver Bullet - '02 Golf TDi
Nice video, Ben...thanks! I'm a real "how it's made" fan, so I like vids that show contactors and other such mechanical niceties.
I'm also hearing impaired, so can't "hear" the bike because of the music (perennial problem for me...). Would really like to see some video without music so I could come closer to appreciating how quiet your bike is.
Thanks! Stan
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 03-31-2008, 09:10 PM   #39 (permalink)
bennelson's Avatar
S10 - '95 S10
Another article on the cycle
Hey Everyone,
There is an article on HellForLeather about my motorcycle.
See it here:
http://hellforleathermagazine.com/20...tric-bike.html
Stan - note taken about sound. I will be sure to do a "no background music" section when I do a real video about the cycle.
Old 04-01-2008, 10:47 AM   #40 (permalink)
That's an awesome writeup! Congrats.
What's your best motorcycle MPG? MetroMPG Motorcycles / Scooters 142 11-19-2009 08:57 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 857 11-16-2009 01:33 PM
Dirt-E Bike (Kawasaki KE-175 Electric Conversion) FrankG Fossil Fuel Free 10 10-08-2008 06:38 PM
Motorcycle fuel economy champ's advice for efficient cross-country touring... MetroMPG Motorcycles / Scooters 6 01-31-2008 02:38 AM
Video: sweet electric Yaris is driving! (Conversion) MetroMPG Fossil Fuel Free 1 12-15-2007 02:11 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
