help on controller
I have the battery pack hook up, the + line goes in to a switch, then into the fuse block, out to the contactor, then to the B+ on the controller then to the motor A1, and the other end of motor A2 goes to M-, and the B- goes to the - side of the battery pack. Then the red wire goes to 12 volt B+, and black goes to ground. And the next 3 wires go to the pot box. I have 3 pins on the pot bot, pluse 2 wires red and black. How do I hook it up? I have pictures, but I dont know how to get them here, DO you? Will this help? Do I have it hook up right? Thanks Ken
