Old 09-08-2010, 02:47 PM   #51 (permalink)
EcoModding Newb
Acura TSX - '06 TSX
90 day: 29.95 mpg (US)
Lafawnda - '01 CBR600 F4i
90 day: 43.18 mpg (US)
Jeep - '02 Liberty Sport
90 day: 18.02 mpg (US)
I removed the fan from my F150 a few years ago. At first I carried it and a wrench in the cab so I could put it back on if needed. Now the fan is hanging in the garage.
That's what I figured. My Dodge Ram Cummins has a fan that moves a terrible amount of air just after starting, even if it's well below freezing outside. I've wondered what would happen if I just yanked it out. Sadly, I will likely just part ways with the old yellow beast soon.
Old 09-08-2010, 10:41 PM   #52 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
I think it's a compromise between the electric fan and the grill block. If you leave the grill in OEM condition then sure you only use the electric fan on the 95 degree day in trafic with the A/C on. If you block 90% of the grill then you run the fan full time after warm up on a 70 degree day. So find the engineering sweet spot. Cover enough grill to decrease you Cd (improve your aero) but not so much that your running the fan all the time and converting all the fuel you saved in aero into electrical energy to run the fan.
I put the LED on the dash to see when fan runs to get a good idea. An 80 degree day at 50 mph with 80% grill coverage causes the fan to run abot 40-50% of the time. Still leaves me a little margin for the 95 degree day and probably really improves my warmup time on my short commutes. Just another thing to trade off in the hunt for mpgs.
Old 09-09-2010, 12:09 AM   #53 (permalink)
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
I've been thinking of pulling the fan out of the truck. Seems like it never engages.
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
Old 09-09-2010, 12:35 AM   #54 (permalink)
pletby's Avatar
The Car... - '98 Contour GL
Team Ford
90 day: 30.94 mpg (US)
GS400E - '83 GS400E E
I never have any problem telling if my fan is on. It's electric and wakes the dead! Heads always turn when I drive by from the racket. I'm thinking I have to look at what's going on under the hood. Maybe a aftermarket fan will be quieter. Also, my car overheats on 30C days in traffic with a/c on. Not that I ran the a/c much this year; trying to increase my mileage.
Now with new driving techniques, my fan doesn't engage before I get home from work.
Best trip: 42.6mpg
Best tank: 32.39mpg
Old 09-09-2010, 10:55 AM   #55 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
If your fan is that loud and you have overheating problems, the fan may be dying and not pulling enough air. My e-fan is pretty loud, but it moves a ton of air, and I know it's still good, as it was replaced about 1.5 years ago.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 04-11-2012, 12:39 PM   #56 (permalink)
radioranger
ppoular Hot rodding did a dyno test a long time back where they showed an older style steel fan cost as much as 60 HP on a race motor, tryed running around my old 289 Mustang wihtout the fan and you could defintiely feel the difference so i'm guess it will help . just worried about underhood air temps on the ranger
Old 04-11-2012, 01:45 PM   #57 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
60 HP? I'm hoping that's a typo. I've had vehicles with engines smaller than 60 HP, and they seemed to be able to power a radiator fan!
I did some work a while back with a guy who built a drag strip SS. I noticed that car didn't have an alternator on it, and he said it was because the alternator would steal horsepower that could otherwise be used to propel the car! I think he said it was as much as a couple horsepower.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-11-2012, 02:13 PM   #58 (permalink)
radioranger
They were taking a real world race engine and dynoing it, it must be more than a few Hp , I'm talking the old steel type because every car today has either a clutch fan or a electric one, It did seem high , I figure though it was at least 6 hp otherwise the belt would slip . I was quoting the article. I think if you can feel the difference its got to be 5 hp difference , not cruising of course its accellerating the fan, I put a bigger alternator pulley on my truck and you could feel the difference right away, if you are in start and stop traffic it is a big difference, due to the idecrease in momentum of the heavier part, thus a fluid clutch or electric willl be much better in city driving MPG than highway where you are steady state, Think how much power it would take to accelareate a four of five pound steel fan with pulley to 5000 Rpm in a few seconds thats where your power loss is. I forgot the math on doing the calculation but somebody could figure it out I'm sure
Old 04-11-2012, 02:20 PM   #59 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Over on dieselplace there is something called "dinosaur fan mod", where you put a radiator fan from a military hummer into a chevy 6.2L or 6.5T diesel truck.
The fan was tested and reportedly to used over 40 horse power at max engine speed.
Now the max speed on those engines is between 3600 and 4400 RPMs. A race motor can turn well over 8,000RPM no problem. To double speed on something like a fan you have to 8x horse power as long as the blades don't stall.
Just driving down the road at normal engine speed a dinosuar fan could be using 5hp or more if the fan is engauged.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
[CRXMPG Mailbag] Radiator Fan Switch SVOboy EcoModding Central 10 04-14-2011 05:25 AM
Electric assist for SUV? Tony Raine EcoModding Central 6 02-25-2010 01:45 AM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 12:19 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
How get a shorter belt........ }{ead$hot Zod EcoModding Central 4 04-23-2008 11:13 PM
