Old 09-18-2008, 06:00 PM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by larryrose11 View Post
I know a bit about electric water pumps...
That was some good info, thanks.
Old 09-18-2008, 06:49 PM   #12 (permalink)
CobraBall's Avatar
Electrical water pumps are common in auto racing.
<http://www.jegs.com/webapp/wcs/stores/servlet/category_10001_10002_10135_-1_10131>
They can be controlled electronically to adjust the rate of coolant flow "even after engine shut down".
Plan on purchasing an extra motor. You can get a engine driven mechanical water pump just about anywhere. Try to find the replacement water pump electric motor at your local Auto Zone.
I considered putting an electrical water pump on my '33 Ford but gave up the idea. Most electrical water pump mgfs. say they pumps are for racing only.
Simple is usually more reliable.
Old 10-16-2008, 03:25 PM   #13 (permalink)
CobraBall's Avatar
Excellent discussion for an Electric Water Pump installation.
EWP Installation
Old 10-16-2008, 03:30 PM   #14 (permalink)
At the same time, a heating element in a pipe can be installed inline with the bypass and a simple control circuit used to make a crankcase heater.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-16-2008, 04:52 PM   #15 (permalink)
F150 - '97 F150 Lariat
Taurus - '02 Taurus SE
the 73 - '73 Thunderbird
the race car - '95 Thunderbird LX
The Brick - '98 LeSabre Limited
they work great on daily drivers.
they also work great on race cars.
I run one on my 95 bird....the beauty of it for me, is I can cool the car off(going from 190 degrees to 170 degress in minutes) in the staging lanes before the next race, with the engine off!
parasistic drag from any accessory hurts any kind of mileage or power.
depending on the vehicle make, some e-water pumps come with an idler pulley built in, so belt routing stays the same.
Old 10-17-2008, 11:08 AM   #16 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
Efficientcy question
Ok, I like not having the drag on the belt driven waterpump on my engine. Since the E-pump will have to runn all of the time, how much more drag will be placed on the engine due to the alternator supplying power for the extra electrical load?
Since there are probably soooo many variables, let's limit replies to hypermiling road vehicles with a small V-6 or less ICE. Thanks
Old 10-17-2008, 01:20 PM   #17 (permalink)
the one pictured above, only has a 7 amp draw.
http://store.summitracing.com/partde...5&autoview=sku
Old 10-17-2008, 10:13 PM   #18 (permalink)
Hey guys,
First of all, I wouldn't undertake something like this if you are not comfortable programming a micro computer of some sort, like an Motorola HC11.
Your effots could be put in a better place, like switching over to a manual rack and pinion steering, or plug in battery w/ alternator field kill switch.
Isn't the PWM control just a matter of using a MOSFET controlled by a common PWM chip? For temperature feedback, just mount a sensor on a pipe and use it to increase the duty cycle of the MOSFET. And maybe also add a PWM circuit for the radiator fan as well, and perhaps a servo motor for opening and closing the vents.
BTW, a friend of mine showed me a "desktop supercomputer" she designed the cooling system for. It was complex enough that the cooling system, consisting of a 2HP BLDC scroll compressor, R-410a refrigerant, a large condenser, 9 PZEVs (8 for the main CPUs, one for compressor cooling), and 8 evaporators, had a 200MHz CPU just to run it! Of course, that was because the CPUs had to be kept below -40C to operate correctly. An automobile engine is nowhere near as sensitive to temperature variations as a high performance CPU.
Old 12-30-2008, 11:22 PM   #19 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
I don't think you have to build your own controller any more
check this out - I've been drooling about it for a while
EMP/Stewart Components E558AR - EMP Stewart Electric Water Pumps - summitracing.com
55GPH - 10,000 hrs estimated life - 8 amps - inline and small
I'm guessing with the box on the side & the reliability expected, the motor is brushless
only thing holding me back is the price
Concrete
Start where you are - Use what you have - Do what you can.
Old 12-31-2008, 01:09 AM   #20 (permalink)
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by Tango Charlie View Post
I think most thermostats have a small hole in them so they still circulate a small amount of coolant when closed. At least the thermostats that I've seen.
No to source to cite (other than myself), but it is an over simplification to think of an automotive thermostat as simply a two state (on/off) device.
If you take a new one and toss it in to a pot of cold water on a stove over low heat, you'll see it slowly open as the water temperature nears the thermostat's nominal operating temperature.
“Revenge of the Electric Car” Coming in 2009 SVOboy EcoModder Blog Discussion 16 02-02-2012 01:49 PM
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 08:53 AM
Electric assist for SUV? Tony Raine EcoModding Central 6 02-25-2010 02:45 AM
Turning off electric hot water heater when not home? ZachUA Saving@Home 33 12-09-2009 10:51 AM
Article: Electric Subaru Due in 2009, One Year Early MetroMPG Fossil Fuel Free 8 08-29-2009 01:19 AM
