Old 10-30-2011, 09:10 AM   #21 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Wow! Now that's something Slow, compared to the 'instant' open of my grille block (I should post a vid), but the 30-40 seconds it takes is enough.
Nice work, augustinionut, and welcome to EcoModder
Old 10-30-2011, 11:43 AM   #22 (permalink)
...beats walking...
...yes, "Welcome," and how much current does that motor draw while operating?
Old 10-30-2011, 11:53 AM   #23 (permalink)
Really, i don't know But because of that long time to open-close, i will use a choke cable this winter to operate-it, untill ill find a rapid servo.
Old 10-30-2011, 12:23 PM   #24 (permalink)
...beats walking...
...one nice aspect of the motor-driven shutter is that it can be stopped & started at any time to achieve "air flow-control" so the radiator doesn't over heat.
Old 10-30-2011, 12:41 PM   #25 (permalink)
I used only to speed warmup of the motor, for fuel economy and for driving fast, faster in winter mornings
I need your help: there is a large bimetal blade capable to pull my grillblock? Sticked to exhaust cover plate?
EDIT This will work?
Old 11-02-2011, 03:23 PM   #26 (permalink)
Look what i found.... silich.ru/zhal.html
Old 11-22-2011, 12:13 PM   #27 (permalink)
Did someone tried to use exhaust heat to warm the car (the engine)?
Until now:
Old 11-23-2011, 04:29 AM   #28 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Maybe someone could use this controller for a grill-block-gizmo:
Autospeed article: $25 Temperature Controller and Display!
I agree that best place for temperature measurement is radiator return line. Example if normally radiator drops temperature from 90 C to 70 C then you set threshold to around:
if temp higher than 75 then open grill, shut grill if lower than 70
Meelis
Old 12-05-2011, 03:15 PM   #29 (permalink)
Last preparation:
Old 12-05-2011, 03:18 PM   #30 (permalink)
aero guerrilla
Piwoslaw's Avatar
Nice!
I wonder how it will work at speed, when air pressure will be pushing it?
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
