Old 01-11-2017, 01:32 PM   #1651 (permalink)
Failure doesn't equal a scam.
When did Tesla start?
Old 01-11-2017, 01:59 PM   #1652 (permalink)
Tyrant-at-large
Vman455's Avatar
Little Red - retired - '05 Honda Civic EX
90 day: 49.03 mpg (US)
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 44.18 mpg (US)
Well Elio could have just used a simple off the shelf motor with proven reliability and low cost but they chose to build their own whizbang VVT powerhouse. Not just the engine but other aeras they will probably try to do things to shave weight to try and up MPG potential. Not necessarily bad if it ends up holding up under day to day use.
I heard that the Dodge Bros used to work for Ford. They left and started building their own cars that were basically overbuilt. Ford went as light as possible, and as cheaply as possible, but still have good enough quality. Good enough is good as long as you hit that mark, otherwise you have a peice of crap. If you want something to be something 20 years later the Dodge Bros idea is probably better. I heard this rumor again in the musclecar years but with Chrysler vs GM. GM had the money and engineering to get things just strong enough to hold up which help them build a car that many not have had the HP of the Dodge but was just as quick as it was lighter, especially in the drivetrain. Dodge just would stick a Dana 60 and a beefy Torqueflight behind their big guns. I do believe the early Dodge stories to be true but think by the 60's everybody had good engineering. If Dodge was still overbuilding it was by design.
I personally would prefer overbuilding at the expense of some MPG or performance. I have had 2 personal watercraft, a Seadoo XP and a Yamaha Waterside. Both 1995's, both the same CCs. The Seadoo is faster but has eaten it's motor 3 times and is now gone. The Yamaha just starts every spring, runs hours in end however hard you want, gets put away wet, and has never had an issue in 20+ seasons of use.
I visited the LeMay collection in Parkland this weekend, and they had a Model T with a Dodge engine in one of their warehouses. The docent said Dodge was actually contracted by Ford and several other manufacturers to provide engines starting in the 1910s, which was responsible for standardizing left-hand driver position in the US.
Old 01-11-2017, 03:26 PM   #1653 (permalink)
They do double damage- not just to investors, workers and the market, but in the future. Now we've got another example of why a small, fuel efficient vehicle using current technology "just won't work." As if it were the car's fault or something.
Exactly, they were sucking up all the oxygen (and money) in the room with what should have easily been seen as too good to be true. Just make a 50-60 mpg $10,000 car and you will be doing good.
Old 01-11-2017, 03:34 PM   #1654 (permalink)
Come ON.
Scams aren't failures either. In fact they pay quite well.
Fat Charlie (01-12-2017)
Old 01-11-2017, 05:35 PM   #1655 (permalink)
Think of all the 'money-making investment opportunities' that couldn't get off the ground in Elio's shadow.
I still liked the Edison2 better.
Old 01-12-2017, 01:33 PM   #1656 (permalink)
Come ON.
How would you suggest financing an ambitious start up?
Also, don't ignore the other sentence of my post - Tesla has succeeded in their primary goal - which was to get electric cars on the map, and they seem very likely to continue to build many electric cars, themselves.
Old 01-12-2017, 02:27 PM   #1657 (permalink)
Can you say Schadenfreude? The happiest 24 minutes I've spent recently. Eight minutes in, the scammee informs that he is 'Head of Quality Assurance for Malwarebytes'. He then proceeds to control the call and brick the scammer's machine. But then it gets better.
Old 03-07-2017, 04:13 PM   #1658 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.48 mpg (US)
Tiptoe - '03 Honda Civic Hybrid
90 day: 46.49 mpg (US)
90 day: 46.66 mpg (US)
Notably, the Elio website is still up and offering people the opportunity to part with their money.
Someone help me out: has Elio officially gone toes up? Did Elio himself ever admit he was done?
Take it easy
Old 03-07-2017, 05:27 PM   #1659 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
The CNT battery company stayed in business for years after they had effectively zero in the bank.
Reason is they really don't do anything and really don't employ anyone
EcoloCap Solutions - Turning the Future Green
Heck they are still around 6 years after bankruptcy.
Old 03-07-2017, 06:42 PM   #1660 (permalink)
I'm just some guy on the internet but if you choose to believe me, the company I work for is part of the supply chain for a few Elio components and we're still in business with them as of right now. I am under NDA for specifics, and since I work for a whole different group within the company I don't have a lot of information anyway but I can state that I believe Elio will still deliver.
2005 Escape 2.3 MT 2WD
2002 Mustang 3.8 AT
2015 Ram 1500 5.7L 4WD
2002 Motobecane 700DS
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
