Old 04-30-2016, 04:04 PM   #11 (permalink)
http://arstechnica.com/business/2016/04/airlander-10-largest-aircraft-airship-details-test-flight/
I don't know if you've followed the progression over the years, but the original 'deltoid pumpkinseed' (much like the 2013 CUER shape) progressed to a catamaran blimp configuration, the a trimaran; now the two outer hulls are enveloping the middle one.
Pneumatic walls inherently want to meet at a 120° angle. That's going to be low interference drag, right?
aerohead (04-30-2016)
Old 04-30-2016, 04:24 PM   #12 (permalink)
trimarans
It looks like a number of designers are looking to produce dynamic lift by creating an airfoil-esque envelope
As far as the 120-degree intersections,I might expect someone like Goro Tamai to predict some drag due to hook-vortice interference drag in the absence of 'blending' the skins together; which might be prohibitively expensive and not warranted.Just guessing
Old 04-30-2016, 08:11 PM   #13 (permalink)
Northrup Grumman, Lockheed-Martin and Aeroscraft. The first two seem very similar.
Pneumatics require the bodies of rotation. Someone should update the Goodyear inflatable wing to the Prantl-D high aspect ratio wing and scale that up. With 3D printed micro-scale trussed beams and an acre of thin-foil solar cells.
aerohead (05-02-2016)
