2008-03-14 |
392 |
11.8 |
33.22 |
"First tank, still pretty cold out, 35 lbs pressure in tires, no tune-up done yet." |
2008-03-31 |
411 |
35.28 |
"tune-up done (plugs, wires, oil change, air filter)and tire pressure upped to 40psi" |
2008-04-13 |
426 |
38.73 |
"Deleted A/C components halfway through tank, flipped intake spout around for warmer air going into intake, started to try EOC on downhill stretches." |
2008-04-26 |
449.1 |
10.95 |
41.01 |
"Tire pressure upped to 45psi, doing more EOC than last tank. Also discovered and fixed small gas leak from improper fix of line from previous owner." |
2008-05-14 |
461.4 |
10.8 |
42.72 |
"No additional mods from previous tank. At least 125 miles of pure hwy which is unusual for my avg week" |
2008-05-31 |
424.4 |
11.18 |
37.96 |
"Started to smell gas and discovered another gas leak this tank. Between that and the lower temps I think thats why mileage suffered this tank. I'm also wondering if this being the first tank with the windows down for most of the tank added to the drastic mileage drop, only time will tell." |
2008-06-16 |
670 |
15.5 |
43.23 |
"Had to get a gas reciept for free fireworks so I just added in the extra miles and fuel together to make the numbers accurate. Took a trip to the PA border so numbers were good and still havent fixed the gas leak. Guess I'll have to do that next tank." |
