2009-02-28 |
218.8 |
6.734 |
$1.989 |
32.49 |
"EOC, PNG, some city driving, country roads, cold start short commutes. Odometer at 386." |
2009-02-28 |
353.4 |
9.862 |
$1.989 |
35.83 |
"Road trip to Illinois, mid 50's mph on the way there, low 60's mph on the way back. All country roads, no highway miles. Odometer at 739." |
2009-03-10 |
334.2 |
9.133 |
$1.979 |
36.59 |
"Lot of city driving, some with new Scanguage installation. Set tank fillup for the first time. Odometer: 1073." |
2009-03-22 |
481.5 |
11.27 |
$1.939 |
42.72 |
"1555 odometer
Lots of slow rolling on this tank, 40 - 45 mph seems to be a good speed for the Versa. Installed grill block and valence block part way through this tank." |
2009-04-04 |
478.3 |
11.44 |
$1.99 |
41.81 |
"Some highway driving, some backroad hypermiling to make up for it. Scangauge says I can get 51 mpg on country backroads by EOC. Valence, grill and foglight blocks are on, foglights just at the end of the tank. The foglight block seems to make a big difference, I never was able to get into the low 50's as easy without the foglight block." |
2009-05-02 |
504.3 |
11.3 |
$2.109 |
44.63 |
"Scangauge Tank Readout
505 miles
71 miles tank to empy
15.9 hrs tank
2.2 hrs tank to empty
31 mph avg
$22.50 cost
44.4 mpg
11.3 gallons
1.6 gallons tank to empty
odometer: 2537" |
2009-06-18 |
436.7 |
8.012 |
54.51 |
"51.7 mpg
$17.7 cost
30 mph avg
7.7 hrs to empty
14.2 hrs
232 miles to empty
438 miles
4.5 gal tank to empty
8.46 gal tank
2974 odo
436.7 trip
reduced fuel adj to 5.4%
Lots of good hypermiling on this tank, not much fast driving. I would have run the tank to well over 600 miles, but I am getting ready for a trip and need a full tank." |
2009-06-23 |
336 |
10.24 |
32.81 |
"Soo" |
2009-06-23 |
202 |
4.99 |
$3.84 |
40.48 |
"Sudbury" |
2009-06-24 |
125 |
2.21 |
$3.97 |
56.56 |
"New Liskeard" |
2009-06-24 |
8.28 |
$4.07 |
36.84 |
"Matagami" |
2009-06-24 |
231 |
6.07 |
$4.78 |
38.06 |
"Relais Routier" |
2009-06-25 |
274 |
6.5 |
$4.73 |
42.15 |
"Radisson" |
2009-07-05 |
295.6 |
8.477 |
34.87 |
"Flint
Some gaps: Timmins, Soo, Dorr, South Haven?" |
2009-07-05 |
303.2 |
7.558 |
$2.629 |
40.12 |
"South Haven
12.9% fuel correction" |
2009-07-18 |
265.7 |
7.344 |
36.18 |
"7367 odo
Highway driving, gotta get there quick summer fun." |
2009-07-24 |
10.53 |
$2.56 |
35.9 |
"7745 odo
Still driving fast. Mod list: 5W20 Mobil 1 synthetic oil, grill blocks, foglight blocks (no valence block)." |
2009-08-14 |
379.9 |
9.653 |
$2.44 |
39.36 |
"odo 8125" |
2009-09-06 |
461.9 |
10.66 |
43.33 |
2010-07-23 |
419.1 |
10.39 |
$2.85 |
40.34 |
2010-09-17 |
443.1 |
12.11 |
36.59 |
"Minor spillage upon fill, different fuel station than usual, could be more gas than usual in tank" |
2010-10-15 |
455.5 |
10.51 |
$2.85 |
43.34 |
"back at the home pump.
the last fillup seemed to be a fast pump which over filled the tank and even splashed out a bit. So the numbers for this tank are suspect. Probably could average with previous tank for accuracy.
14,169 odo" |
2010-11-19 |
355.9 |
9.462 |
$2.889 |
37.61 |
"od 14525
moderate hypermiling, no eoc
quite a few short trips" |
2010-12-17 |
387 |
10.03 |
$3.04 |
38.58 |
"14912 od
38.3 tank av mpg trip scangauge" |
2011-01-10 |
393.5 |
10.56 |
37.26 |
"odo 15305
moon hubcaps installed at 15123
lot of snow
some slower driving due to icy conditions" |
2011-04-15 |
378.8 |
10.82 |
$3.96 |
35.01 |
"Quarter year on one tank
odo 15684
bumped Scangauge up to 10.7 gallons on tank, was 10.6
Scangauge read 372 miles on tank" |
2011-05-01 |
440 |
10.16 |
$4.13 |
43.31 |
"odo 16124
trip 440
scangauge:
tank mpg 42.8
10.0 gal
433 miles
35mph avg" |
2011-05-30 |
372 |
7.975 |
$3.94 |
46.65 |
"odo 16496
trip 811.8 - 440 = 371.8
Scangauge Tank:
44.0mpg
8.28 gal
365 miles
32mph avg" |
2011-06-22 |
516.4 |
11.02 |
46.86 |
"odo 17012
Scangauge says 44.9 mpg
little to no highway driving, mostly country roads at slow speeds, some city driving
changed the fuel calibration by -0.1 gallons." |
2011-07-05 |
512 |
10.79 |
47.45 |
"odo 17524
Scangauge Tank: 46.6mpg
Lots of slow driving on country roads, joyriding mostly around 45mph." |
2011-07-26 |
480.3 |
10.24 |
46.9 |
"odo 18005
Scangauge read tank 45.3 mpg" |
2011-08-17 |
477 |
10.74 |
$3.76 |
44.41 |
"odo 18482
Scangauge tank 43.3 mpg" |
2011-08-27 |
427 |
10.027 |
42.59 |
"18909 odo
40.4 mpg on Scangauge
started pulling trailer, just a few miles
more speed limit driving" |
2011-09-10 |
404.2 |
9.586 |
$3.749 |
42.17 |
"19313odo
42.5 mph Scangauge
Starting to commute and not able to drive as slow.
oil change 19312 Mobil 1 synthetic 5W20" |
2011-09-24 |
324.2 |
8.979 |
36.11 |
"odo 19637
324.2 trip
35.2 scangauge mpg
Commuting, highway, in a big hurry " |
2011-10-16 |
393.6 |
10.55 |
37.31 |
"20032 odo
scangauge 36.4mpg
adjusted fuel use down by .1" |
