2013-03-20 |
546 |
14.1 |
$3.94 |
38.72 |
"Chevron Diesel; switched to Shell for this fill up, will report results. 40% city/60% highway. Leaking tandem pump and missing belly pan." |
2013-03-22 |
427 |
9.832 |
$3.93 |
43.43 |
"95% highway at 70-80mph. Shell Diesel. Previously had burps on the freeway, this fuel solved that problem. Lesson learned: only fill up at stations with a lot of traffic!" |
2013-03-30 |
460 |
10.85 |
42.4 |
"Flying J diesel, little-to-no boost for most of this tank due to damaged hose. Back to Shell for this fill up, added Power Service Diesel Kleen. Hoping to hit 45mpg." |
2013-04-05 |
260.5 |
5.222 |
$3.869 |
49.89 |
"Mostly highway at 55-65 mph. Began using Diesel Kleen, great stuff!" |
2013-04-05 |
440.5 |
8.649 |
50.93 |
"Salt Lake City to Las Vegas. Averaged 59.9 mph including three stops; without the stops, I would estimate it being closer to 65. I put duct tape over 75% of the grill with no noticeable impact on engine temperature (ambient temp of 70-80F). Utilized constant pedal technique: maintained 75mph on flat roads, reduced to as slow as 55mph on steep climbs, and EOC down steep descents. Car is still missing belly pan, so I am more than pleased with its performance!" |
2013-04-13 |
357.7 |
8.711 |
$4.019 |
41.06 |
"Fought winter weather and a 30-50mph headwind on this trip." |
2013-04-19 |
570.5 |
13.589 |
$3.869 |
41.98 |
"Included a couple of 120+ mph high speed runs at the Bonneville Salt Falts." |
