01-29-2008, 08:14 PM
#11 (permalink)
She's got a SG and she's motivated. She's gonna beat 22.4 for sure.
01-29-2008, 08:42 PM
#12 (permalink)
Remember: she can't see the ScanGauge.
EDIT: but I can't deny she sounded motivated.
01-29-2008, 09:01 PM
#13 (permalink)
EV OR DIESEL
Is the scan gauge calibrated for the Camry already? why not just compute at fill up if it is hidden.
Not trying to mess up your contest in any way, just trying to determine methods.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
01-29-2008, 09:08 PM
#14 (permalink)
The engine size is set in the ScanGauge, but it's not calibrated against any past fills.
The reason for using the SG is to enable a one week contest and accomodate my short attention span! (Otherwise it would probably take most of a month to drain the entire tank.)
01-29-2008, 09:12 PM
#15 (permalink)
EV OR DIESEL
Roger that
17 in that case
My friends Camry(96 5 speed 2.2) with Scangauge uses 29% on the FCF Hence my low Ball.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
01-29-2008, 09:15 PM
#16 (permalink)
Can you clarify FCF?
01-29-2008, 09:20 PM
#17 (permalink)
EV OR DIESEL
Fuel Correction factor, it is what you adjust when you fill up.
If memory serves the Gallons is on top (which you adjust) and the Fuel correction factor is at the bottom.
A FCF of 29% indicates that the engine is injecting 29% less fuel than it is reporting via OBDII.
Again if memory serves that would make the SGII mpg appear Lower than actual mileage.
Could just that his car has plugged injectors, I don't know, but I'm gambling on the Idea that those cars are alike . . . .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
01-30-2008, 07:04 AM
#18 (permalink)
I'm guessing 23.
01-30-2008, 08:31 AM
#19 (permalink)
Eco Noob
24.5 mpg
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
01-30-2008, 09:47 PM
#20 (permalink)
Here we go again. 23.1516171819..................................... ...........................adinfinitum.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
