Old 03-24-2010, 06:55 PM   #31 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
I made my own thread
http://ecomodder.com/forum/showthrea...tml#post167508
Found this 10 minutes later...maybe moderator can merge my thread here?
This thread should be sticky.
The Following User Says Thank You to meelis11 For This Useful Post:
TOOQIKK (08-29-2011)
Old 03-30-2010, 12:17 AM   #32 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by dcb View Post
Nice yetimus
I agree dcb. Yetimus, you are inspiring me to do something similar for my wife's Avenger. I hope the display is a little bigger though!
Old 03-30-2010, 07:22 PM   #33 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Very nice. What case is that?
Originally Posted by LeanBurninating View Post
Coast long and prosper.
Old 04-19-2010, 11:36 AM   #34 (permalink)
1999 Honda Civic HX 5MT
LinuxGold's Avatar
Hi all, I am looking for enclosures, where can I find them online, specifically for mpguino?
Old 04-24-2010, 12:18 PM   #35 (permalink)
brucepick's Avatar
Gen-1 Insights
Hey, how did that work out?
I set the display into front panel of Radio Shack case first, a lot like what you showed - then I had problems.
My carpool buddy who knows way more elect. than I do said to set it into the main part first using small tube type standoffs + screws, then set on the faceplate. I'm doing a rebuild soon but not sure which way I'll go.
Hmmm - I just saw rmccomiskie's pics here, that looks like a good way too.
see link
Originally Posted by daring4 View Post
Just temp to see how it works...
Old 05-20-2010, 09:55 PM   #36 (permalink)
brucepick's Avatar
Gen-1 Insights
My new case:
47.96 mpg on the 57.67 mi. trip to work this morning.
Previous cardboard case worked great and was compact but not pretty.
New case has rear ventilation slots.
(Later I had to make these MUCH larger, unit would overheat and cut out occasionally. Slots now = approx half the back's surface area.)
New case was made from a much larger case. From an electronic supply place.
Source case had the correct dimension across, about 1/2" bigger than the 4x2x1" Radio Shack case I'd tried earlier (too cramped for this version Guino, imho). I cut down both the height and the depth later.
A car pool buddy with more electrical knowledge and experience than I advised me - after my first plastic case um, failed miserably. Advice: There should be no stress on any circuit board. Mount with screws and non-threaded standoffs (bushings) as spacers. Use non conductive materials wherever possible.
I used #3 screws; they fit the holes nicely. #4 is too big. #2 works but they are kinda loose. My screws and nuts are stainless; the washers are #4 nylon.
At the bottom you see 2 screws, each with 2 washers. They anchor the board to the case.
Detail of one of the 2 upper screws. These are spacers that brace (gently) against the back side of the case front panel. You'll need to CAREFULLY trim away some of the sheet plastic that's between the two circuit boards at the corners. Swiss Army knife scissors did it for me. One nylon plus one thin stainless washer built up the right thickness. Note the nylon is against the board, not conductive.
I basically sliced off the entire lower part of the original full case to the short height I wanted. Then it needed a new bottom. Bottom has velcro to stick to dash so I wanted to have a bottom there. Bottom made from the left over front panel that I trimmed off. Note the cuts to mate with the back of case. That's a fiber reinforced cutoff wheel on the "Dremel", which is actually a Black and Decker. It did almost all the cutting I needed for the project.
Here's a shot showing the cut to reduce the depth. I made a new back from more of the front panel trim-off material. JB Quick "weld" epoxy glued on the new bottom and back. Hot glue might melt in summer heat, and regular epoxy is rated only to 200ºF (from the package info). JB Quick is rated to 300ºF so I feel pretty confident in that.
Can't resist showing the trip home from work today.
The Following User Says Thank You to brucepick For This Useful Post:
Old 05-22-2010, 05:04 PM   #37 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
see link
It was a tight fit into that box, trimmed some off the boards and some from inside the box. Plans were to mount it perm. some where in the car but have been having too much fun EOC'ing! It does work good in there but I should put some ventilation in it like you have done, we got to 100 deg yesterday!
What problems did you have?
Old 05-22-2010, 10:22 PM   #38 (permalink)
brucepick's Avatar
Gen-1 Insights
...What problems did you have?
The problems were with my 1st attempt, in the Radio Shack 4x2x1" box. Carpool buddy thinks I damaged the board by using the friction + pressure fit method. Anyway one day I got into the car and first thing I did was to reach for the center illum. brightness button - and the display fried. I think a static charge hit it from my fingertip. So I had to get the display board replaced.
After what my buddy told me about not stressing any of the boards I decided to do a complete new case. I figure maybe it only fried because somehow I compromised a board. As you see instead of mounting it to the case like he said, I mounted it to the panel; otherwise I took his advice. I think it's good; time will tell.
Old 07-10-2010, 03:04 AM   #39 (permalink)
Not so much a enclosure, but more permanent installation.
Took the middle air vent out of a donor car i have. Made a metal plate to mount the mpguino onto. hacked out buttons from a dead dvd recorder(sawing both pcb and front display part). then some 3m carbon vinyl to hold the metal plate to the vent.
(i pics it is attached with hotglue, but it fell off due to heat. So i instead used the stuff body panels are sealed with, and super glue.)
and ofcourse blocked the air to the side it is mounted.
The Following User Says Thank You to mirkwood For This Useful Post:
Old 07-16-2010, 09:52 PM   #40 (permalink)
brucepick's Avatar
Gen-1 Insights
Slick. I'd say, unblock the air to that side. Cut some slots or such in the metal plate and it will help keep the Guino cool. They build up some heat especially if they get a straight shot of 12-14V.
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
