The Enclosure Thread, Show Yours Off!!
just finished making my enclosure. i like the results. i used some click pen cap internals to make some case buttons. there is also a video showing the function of the case buttons.
http://farm4.static.flickr.com/3376/...eab8e9.jpg?v=0 http://farm4.static.flickr.com/3122/...dae8f3.jpg?v=0 http://farm4.static.flickr.com/3383/...9df800.jpg?v=0 http://www.youtube.com/watch?v=2p79d16vbF8 |
Very similar to mine. For button extensions, I cut up a ballpoint pen refill, cleaned it out and reamed to fit the tactile buttons. As an added bonus, the backlight from the display shines on the button extensions so I have lighted buttons.
http://img10.imageshack.us/img10/9390/img2001awt2.jpg http://img13.imageshack.us/img13/5342/img2002ahd1.jpg http://img12.imageshack.us/img12/3591/img2003amw5.jpg http://img11.imageshack.us/img11/5945/img2004amb3.jpg http://img10.imageshack.us/img10/2245/img2005alc9.jpg http://img11.imageshack.us/img11/4466/img2006ala5.jpg This is a Fundamental Logic MPGuino v1.0. Only the RJ-11 connector is brought outside the box. When I want to connect to USB, I open up the box. Pretty handy actually. Just unscrew the cover and carry the Guino with me. The display is red from SparkFun. |
I like it. Looks quite professionally done.
looks pretty good there. is that the radioshack case your using?
I'm getting much inspiration for my MPGuino build. I actually have a project box sitting around that should be the right size to do the same thing as you, rmccomiskie. In fact, now I have an idea of what kind of room I have to add the LED output for my OEM wideband display in the same box. :thumbup:
I'm using the first version board, so my connectors are on opposite ends. But I should still have room to remotely install the LED array from the Wideband monitor in the same box as the Guino.
I might actually get to building it in the next two weeks. I've been busy prepping/fixing an 03 Honda Odyssey that we just bought. |
I recently finished installing the MPGuino display in the instrument cluster of my '96 Passat TDI.
http://i256.photobucket.com/albums/h...f/DSC00238.jpg I'm pretty happy with the results, but it was a lot of work. In order to find something small enough to fit in the dash, I used Newhaven Display NHD-02161Z-FSY-YBW-C along with Molex 0520891619 FFC adapter. It was quite the crash course in soldering tiny wires! The miniature display compared to the MPGuino original: http://i256.photobucket.com/albums/h...f/DSC00229.jpg The cluster I'm running is out of a VR6 Passat with an auto trans. The automatic cars used a LCD display under the tach face plate to indicate gear selection. My car is a 5-speed so I used the space in the tach face to mount the display. http://i256.photobucket.com/albums/h...f/DSC00224.jpg http://i256.photobucket.com/albums/h...f/DSC00225.jpg I desoldered the original LCD from my Spiffie MPGuino and mounted (crudely, I might add) the board to the back of the instrument cluster. I powered the LCD backlight directly from the instrument cluster lighting through a 270 ohm resistor so the MPGuino display would dim with the rest of the gauges. http://i256.photobucket.com/albums/h...f/DSC00231.jpg Finally, I ran a trio of pushbutton switches in parallel with the tactile switches on the board itself and mounted these under the steering wheel. http://i256.photobucket.com/albums/h...f/DSC00247.jpg I'm fairly pleased with the results overall. The small display has a fairly large space between the top and bottom rows of text which hampers readability somewhat, but not too bad. Also, I was hoping for a better match of the LCD backlight with that of the existing gauges. But it all works as it should and it's been a fun learning experience. |
Now that is just gangsta. Very good! My case is in the mail, I'll post up pics ASAP.
