Old 01-17-2013, 12:29 PM   #1 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
Engine Analyzer Pro with Pictures
Engine analyzer pro is an engine designer for professionals and engineers to simulate engine dynamometers. I have been playing with this sim for about a week now and have had surprisingly accurate results. Now i must warn people that are interested in such software that EAP is very tedious and you need to know a LOT about your engine to get some accurate results. Also its an expensive piece of software. One main reason i'm using this software was to estimate the brake specific fuel consumption or BSFC for my cars (there are a lot of information that this software can provide, BSFC is only one of many). With EAP You basically edit information such as your short block, heads, intake, exhausts, cams/valves and turbo/supercharger. Then you can get your end performance results after the software analyzes this information. this is just a page from the cam/valve spec section that i filled out:
once you enter the information required as accurately as possible then you can calculate the peformance.
EAP analyzing the engine (dyno):
and here is what i got for results on brake specific fuel consumption, brake torque, fuel flow and volumetric efficiency:
BSFC alone:
so according to this simulation my brake specific fuel consumption (SOHC 2.5L impreza) is lowest at 2200-2400 rpm during wide open throttle. I know it's all a simulation but its pretty interesting still. Also there are a lot more information that EAP provides such as knock index, brake horse power, cylinder pressure, exhaust pressure and so on...
Old 01-17-2013, 12:36 PM   #2 (permalink)
ever_green's Avatar
if you provide me with information such as your cam timing, valve sizes, valve lift i can estimate a result for you. i really like to see one for a honda insight so i have something to compare against, since insight is so well documented BSFC wise.
Old 01-17-2013, 12:44 PM   #3 (permalink)
...beats walking...
Q: does that EAP software allow you simulate engine conditions other than WOT, such as part-throttle, high-loading, highest gear--ie: hypermiling?
Old 01-17-2013, 01:49 PM   #4 (permalink)
ever_green's Avatar
no unfortunately only wide open throttle simulations are available.
Old 01-17-2013, 02:52 PM   #5 (permalink)
It just so happens that 2320-2800 rpm = 1000-1200 ft/mn piston speed.
Old 01-17-2013, 03:21 PM   #6 (permalink)
Adventurist!
CLaero - '97 Acura CL Premium
90 day: 34.59 mpg (US)
CR-v - '03 Honda CR-V EX
90 day: 26.52 mpg (US)
Wow, I would LOVE to have that software to tinker with!
'97 Acura CL 2.2L 5spd
'03 Honda CR-V 2.4L EX 4wd Auto
Old 01-17-2013, 04:39 PM   #7 (permalink)
ever_green's Avatar
yep its a lot of fun and if you know what your doing and read the 240 page manual its accurate too. you can download the trial or the older version for free if you google a bit. ill be working on the gm 1.4l turbo and a 1.8l honda next.
Old 01-17-2013, 08:08 PM   #8 (permalink)
Adventurist!
Ah... no version for Macs. guess I'll have to dust off the old laptop!!!
Old 01-18-2013, 10:57 PM   #9 (permalink)
ever_green's Avatar
ok here is one with cummins 5.9L with truck diesel fuel
compared to official results:
http://ecomodder.com/wiki/images/1/1...9-175_BSFC.gif
Old 01-18-2013, 11:09 PM   #10 (permalink)
I think usually the case is that peak BSFC is at a slightly lower rpm than the peak BSFC at WOT. Your peak WOT BSFC is at ~2000rpm, which is a really slow engine speed! Peak BSFC might arrive at something like 1900rpm and 85% of that torque.
