Old 07-03-2008, 04:32 PM   #11 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
You've got it figured out. I would say if you are racing, you want the configuration on the left for engine longevity, but if you're ecomodding, you want the configuration on the right. You could even go so far as the block off the outter 2 thirds of the top opening as well as the whole bottom, then seal it as your diagram shows and figure out how to duct it out to the wheel well. With good ducting and 80% blockage, you'll probably end up with the same cooling as no ducting and no blockage, but gain a huge aero advantage.
Old 07-03-2008, 08:25 PM   #12 (permalink)
NismoMax80's Avatar
Max - '04 Maxima SE
90 day: 24 mpg (US)
looks like you guys already addressed options before
aero-mods,installment#9(internal drag)
i still think those blocking grilles and covering underbodies need to give this aspect thought.
my current project
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
