09-14-2008, 11:53 PM
#21 (permalink)
Renaissance Man
How are you all determining when your injectors have stopped firing? Are you going by the cutoff feature in the Scangauge? Or have you wired up LED indicators? I'm still very curious about this. I'm not convinced that my car does this, but I can set the "fuel cutoff" setting in the SG according to the manufacturer's instructions and see cutoff indicated by "9999MPG" under certain coasting conditions. But as best as I understand it this is just a guess. On the other hand, one of my manufacturer-specific X gauges is fuel pulse width, and I never see this register zero under any coasting conditions. Thoughts?
More choices...
09-15-2008, 12:07 AM
#22 (permalink)
The mpguino reads all 9s when fuel is cut. But long before having that, I could tell when mine cuts the fuel. It feels different. The exhaust note disappears. And when I tried an O2 sensor monitor once, it shows nothing when the fuel is cut.
Winter daily driver, parked most days right now
Summer daily driver
09-15-2008, 12:20 AM
#23 (permalink)
You could wire an LED with a 470 Ohm series resistor directly across a fuel injector. The LED would light up to its full brightness whenever the injector is NOT firing. It will be progressively dimmer when the injector is injecting larger amounts of fuel.
Better yet, connect a voltmeter directly across the injector's two wires. Turn on your key but do not start the motor. Read the voltage. This is the full source voltage when the injector is NOT firing. Now start the motor and notice that this voltage will drop and drop further when you are accelerating (using more fuel).
Anyway, when driving, coasting, etc. just look at that voltage. If it reads the same as the key-ON, engine-OFF voltage then you know that your engine is not using fuel.
EDIT: I have that a bit backwards... If the key is ON but the motor is not running, the voltage measured across the injector will be zero volts, not full source voltage. My above numbers would be correct if you wired the voltmeter the way I did to my vehicle, which was to connect the meter between circuit ground and the switched side of the injector (not the powered side of the injector). Same applies to the LED circuit.
09-15-2008, 01:36 PM
#24 (permalink)
The TC - '88 Thunderbird Turbo Coupe 90 day: 28.03 mpg (US)
I know my tbird cuts fuel until it drops to 2000 rpms coasting, not sure about the festiva though, Im gonna guess lower rpm, as its a total economy car and has much more usable low end power.
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
09-15-2008, 06:48 PM
#25 (permalink)
Since Dane-ger said he had carbs, not fuel injection, it reminded me of what another member of my car pool once did (this will give away how old I am!).
He had a 1956 Ford with the 312 T-bird engine. On a couple of downhill stretches on our commute he could flip a switch to a valve that let outside air into the intake manifold, and that killed the flow of air through the carburetor. Supposedly this saved gas, but I wonder what kind of damage this might have done to the engine, plus the engine cooled too much on long downgrades.
He had an automatic transmission--no lockup in those days-- but the engine kept turning. Maybe the early Ford automatics had a rear pump like the early Mopars did that allowed this to happen.
Ray Mac.
06-24-2009, 06:50 AM
#26 (permalink)
if you have to have power full time power steering - go electric!
one of my diesel rabbits has 4 additional vacuum tanks i can do reeeeeeeally longs hills
that way...
06-24-2009, 11:40 AM
#27 (permalink)
I changed over steering to manual and brake booster to electric for coasting (and elimination of engine belt drains).
(If I don't need power steering in my giant truck, nobody does)
But on long steep descents I really want to be able to engine brake to preserve the brakes.
This was easy for me, because I have a diesel.
The engine kill switch I already installed on the shifter cuts off the electric fuel pump. All I have to do is hold it down for as long as I want to engine brake. A couple jobs in the hills past couple days, used this feature a whole lot.
"I would usually take off on foot in the morning and being the gentleman I am---and to make a point about the inefficiency of car ownership---leave Dear Wife to dig out the [snowed in] car to drive to work (we worked in adjacent buildings). I would always arrive before her." http://forum.earlyretirementextreme....pic.php?id=881
06-24-2009, 01:38 PM
#28 (permalink)
Originally Posted by MetroMPG
That's one area I'm less familiar with (I rarely drive an automatic). I suspect they can only fuel cut when the torque converter is locked, otherwise the engine would stall out.
Not necessarily, my father's Bravada will cut if I shift down to 2, and EB down a hill at 25-30 mph. I do not know if it's locking the converter or not, though.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
06-24-2009, 02:26 PM
#29 (permalink)
I can't tell if my father's truck does it or not, the 2.2L doesn't have much back torque to begin with. But on his Bravada, it's very noticeable when the engine stops receiving fuel. It also has a factory gauge, which hits 99mpg when the injectors stop.
06-24-2009, 02:31 PM
#30 (permalink)
Ray Mac.
Pretty much anything prior to the 60's had rear pumps, and most from the 60's did, too. But even without a rear pump, there's enough pressure built up in an automatic going at speed that it won't drop the motor until you get to a very low speed.
