File fit oil rings, with a real narrow gap. 14 to 18 thousands top and a little wider 2nd gap.
Raise the compression ratio.
Put a block heater on the engine.
Reduced oil ring tension.
http://ecomodder.com/forum/showthrea...ger-29085.html
