Old 03-31-2010, 08:33 PM   #1 (permalink)
engine compatibility
heyeveryone,Ihave a 95 and a 96 geo mettro. the 95 waspurchased for the transmission.. I pulled the motor and trans from the 95 and am putting it in the 96. what needs to be swapped over with the trans? since the 95 is obd 1 and the other is 96. I noticed a sensor by the oil pan what is this?
Old 03-31-2010, 08:48 PM   #2 (permalink)
anyone ? should I continue putting the 95 motor in or just use the 96? the 95 still has trans attached, both motors have similar mileage.
Old 03-31-2010, 08:48 PM   #3 (permalink)
ceej's Avatar
Box - '99 Metro Base
Transit - '010 Transit Connect Van XLT
90 day: 23.2 mpg (US)
Crank position sensor perhaps.
You may have a time of it. I did a 96 to a 94 a while back. It required swapping the manifold and all the fuel injection stuff over to the newer engine.
If there are differences, pull the manifold from your car and mount it to the new(er) engine. The ECM and harness may be different. I'd save lot's of bits and pieces. Look all the electrical connectors over for differences. You may need to swap various items onto the new engine.
CJ
The Following User Says Thank You to ceej For This Useful Post:
awd-dsmer (03-31-2010)
Old 03-31-2010, 09:00 PM   #4 (permalink)
well their both fuel injection, o nly differences are obd1 and obd2, imjust not sure if whats under the bottom pylley is a crank sensor or something.. anyone else know?
Old 03-31-2010, 10:32 PM   #5 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
OBD2 96 Nissans had a sensor that counted the teeth in the flywheel ring gear. It was used to accomplish passive cylinder balance testing to determine which cylinder was not producing as much power as the rest the were operating normally.
Sensor was located in the bellhousing.
If that is what you are trying to describe it is not a functional necessity, but a diagnostic tool. It will give you a check engine light on the second start, and will keep doing it after you reset the check engine light. Second start check engine light indicates a non critical malfunction.
Not sure if your OBD2 works like the Nissan cars in 96, but I am pretty sure it was required so you could check cylinder balance percentages without changing or disconnecting anything, like disconnecting plug wires.
Might need to swap the bellhousing to make it work right, but I am no expert on Metros.
regards
Mech
Old 04-01-2010, 03:12 AM   #6 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
There are several metro-specific lists where highly detailed answers to such queries appear.
Old 04-01-2010, 09:41 AM   #7 (permalink)
wow thanks bicycling bob. for nothing. Im posting this question because ive looked and cant find any "lists" and yes ive searched. instead of telling me there's lists you could A) Link. B) Quote or C) answer the question. you did none of the above.
Old 04-01-2010, 09:42 AM   #8 (permalink)
sorry to flame. i just hate wasted posts.
Anyone have anything usefull to add?
really appreciate it if you do =)
Old 04-01-2010, 10:00 AM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
You did not mention if they are 3 or 4 cyl or even auto or stick, there wasn't a whole lot to go on in the initial post.
Also if you are in a testing area you will want to keep the obdii system intact if the resulting frame is a 96.
Old 04-01-2010, 10:20 AM   #10 (permalink)
How to ask for help
I didn't know you had looked. I thought they were easy to find. I didn't recommend my favourite group because it goes off topic a lot and thought you'd rather choose yourself. Now, I won't recommend any group for you.
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
efficient engine design Old Mechanic EcoModding Central 22 01-01-2010 08:00 AM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
