Old 01-22-2010, 04:29 PM   #1 (permalink)
replacing inverter on Prius 2004
Hi,
The inverter of my prius is damaged, as per Toyota, and need to be replaced.
Supposedly because the battery was charged with wrong polarity. I towed it to the shop when my car did not start, and the fuse was blew up at the time. They replaced both fuse and battery. About 24h later, my car was not working fine and I brought it back; they then told me the inverter was to be replaced.
Does the story makes sense ? it would imply somebody in my family charged with wrong polarity and did not tell me... hum hum...
Anyway, if I buy the part on eBay, is it reasonnable for me to do it myself ? what documentation would I need, and approximate labor time ?
Thanks !
Old 01-22-2010, 07:24 PM   #2 (permalink)
If you can still drive it, the inverter is most likely fine.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 01-23-2010, 12:22 AM   #3 (permalink)
Thanks for your help !
Strange the dealership saying so ? they would have to be very very confused.
So here are the symptoms:
- car works fine
- battery recharges when the car moves
- there is a big red !! sign. This sign signifies that something is WRONG.
- the battrey is not getting charged (from the screen picture) when the car is not moving eg at a red light
Old 01-23-2010, 10:07 AM   #4 (permalink)
- car works fine
Use a Scangauge to check the error code.
Old 01-23-2010, 02:06 PM   #5 (permalink)
code is P0A08-DC - DC inverter status.
Old 01-23-2010, 08:58 PM   #6 (permalink)
Try asking on Priuschat.
Old 01-24-2010, 04:00 PM   #7 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Before you do anything, check the voltage of the 12V battery in the back of the car. It should read 12.4 and above with the car off and 13.8 or so with the "ready" symbol on. If it's showing anything in the 11V range or lower it may be shot although it may be just low on electrolyte.
These often die on the Prius and can cause all kinds of strange error messages. The 12 volt battery can be replaced with a non Toyota battery more cheaply from an auto parts supplier. The fact that the car runs means that the 12V system is getting power from the DC-DC converter. If you can clear the code with your scanguage do that and see if it happens again.
The dealership blaming you without evidence is a nasty tactic. There are many cases of the dealership just throwing parts at a problem without diagnosing properly. They like to sell you their expensive parts.
Please go to Prius chat where there are many expert people who can help you. PriusChat Forums
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Daox's 2004 Toyota Prius Build Thread Daox Hybrids 241 07-23-2020 02:09 PM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
Is a Prius inverter good for an EV? etc Hybrids 13 12-13-2009 10:09 AM
The hybrid allure - my quest to learn about and acquire a Prius Daox Hybrids 52 07-13-2009 05:36 PM
