Old 01-14-2010, 01:00 PM   #1 (permalink)
Engine Coolant Choice
GM Dex Cool -----orange color----Oreilly
Toyota Long Life coolant------red/pink----$21 at carquest
Prestone Ext Life any color ------color kinda clear ---Wally world
Least expensive coolant branded for retailers -------yellow/urine color
Anyway I am considering using prestone ext life coolant(any COLOR) for my 04Prius!
Prestone 800 phone hotline say this is compatible for that application.
Local ASE mech says the same.
I have notice many Toyota owners have been sold on mfg dealer branded products and color dye agent.
please view this link too
http://http://techno-fandom.org/~hob...00k/part5.html and
http://sancarlosradiator.com/antifreeze_coolant.
04SlvPrius
Old 01-14-2010, 02:11 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...if still under warantee, use appropriate "factory / OEM" coolant (and parts).
...if not under warantee, clean & flush thoroughly, and use Prestone.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
TexasCotton (01-14-2010)
Old 01-14-2010, 02:30 PM   #3 (permalink)
Answer to 2nd statement first and not to be ugly!
Most auto mfg warranty 3yr/36m unless having ext warrant. The vehicle has no warranty. aka 04SlvPrius
Next,OEM coolants use dye color agents so you come back to local dealer for product. Drain coolant fluid yes. Flush/clean is almost impossible on this vehicle. Like saying "flush/clean" brake line and master cylinder.
Old 01-14-2010, 02:37 PM   #4 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I agree with it being under warranty to use the factory suggested coolant.
But why so adamant about the Prestone coolant?
I buy the Murrays concentrated (green) coolant from O'Reilly's Auto. It's only $9 and makes two gallons of 50/50 mix as opposed to $9+ for the 1gal premixed stuff and the $11+ 1gal. Prestone extended premixed?
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
The Following User Says Thank You to TomO For This Useful Post:
Old 01-14-2010, 03:00 PM   #5 (permalink)
...beats walking...
...why? (a) known quality history and (b) 'universal' compatibility with other mixes.
...other than that, no special reason (cost not considered either).
...maybe even "PEAK"?
TomO (01-14-2010)
Old 01-14-2010, 03:02 PM   #6 (permalink)
Prestone
Not really "adamant" or adams ant bout any coolant producer. I use Oreally too for bout everything. Oreily house brand is prestone.
End users have mixed coolants choices in the past. Big no no is using low cost yellow "old school" engine coolant with ext life or long life.
GM got sued over Dex Cool
I am just wondering what the coolant formula makeup. of Toyota Long Life coolant (red/pink) (borate free) and true differentation might be.
Water quality varies . Coolant quality, formula makeup and proper application are important.
However the rest like color dye agents and word marketing aka "long life" "ext life" are just that marketing and branding.
Old 01-14-2010, 04:14 PM   #7 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I use the cheap green stuff. Always have and why not? It always works. And it's cheap. And it works.
Why, when something works, bust a nut to find something else?
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
TomO (01-14-2010), wagonman76 (01-16-2010)
Old 01-14-2010, 04:27 PM   #8 (permalink)
That VX guy!
TomO's Avatar
I say Amen to that!
I use the green stuff 50/50 mixed with distilled water. Every year I stick the positive lead from my Voltmeter in the water fill in the radiator fill neck (in the coolant) and the negative lead on the negative battery terminal. When it starts reading more than .01V it's time to change the coolant.
Source: Checking for Electrolysis in Coolant
I'm pretty tight with my money (have to be , I only make $17K a year) so I tend to squeeze as much life out of things as possible.
Old 01-14-2010, 04:39 PM   #9 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I hear ya re: budget.
Last fall I got around to flushing/changing the coolant in my '94 F150. The FACTORY coolant.
I'm sure many would howl at the callousness of my abuse; however, it's the only vehicle I've ever bought new, and I've taken care of it from day one. Over the years I have checked the coolant, for color and with the hydrometer. Like other things on the truck, I finally changed it out of pure guilt. Like the air filter element I changed at 80,000 miles and over 10 years old- changed out of pure guilt because really, it wasn't filthy and could have stayed in service. This is the truck that still proudly wears the factory battery! In MN!
Oh, and when I did the coolant flush, there was no evidence whatsoever of any cooling system problems. There was a wee bit of sediment in the overflow tank. A visual down the radiator neck showed no accumilation of anything. Oh yes, in addition to the 16 year old battery, it proudly wears all the original hoses and plug wires. Shoot, I have replaced the serpentine belt once though.
Old 01-14-2010, 06:18 PM   #10 (permalink)
Driving the TurboWeasel
As an owner of a GM car that had Death-Cool in it, I like having choices. I'm using the Prestone extended-life since it was BOGO and I had a rebate back when I last changed it after the lower intake gaskets were changed. Saved another 3800, yes!
I'd use the mixes-with-any kind after flushing as much of the factory stuff out as possible.
2012 Chevrolet Cruze Eco 6MT
Keeping Engine Coolant Hot Raysp30 EcoModding Central 18 12-08-2011 07:57 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
Leaking Engine Coolant m.portice Off-Topic Tech 3 06-10-2009 11:52 AM
