Old 05-03-2016, 01:43 AM   #21 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
My english is bad, so i didtn wrote long texts here :X
The original EFI was only 180mm long. To reduce the RPM and higher the tourque, i used this EFI. Smaler, longer but with a smooth surface and good tubelining. The "snakehouse"-form equals in a "drill", wich optimize the nebulization at low rmps.
Runner lenghts are now 370mm, the diameter 31 and a smaller plenum.
With the deleted flowmeter (used now underpressure and the temperature to calculate the fuelflow), this big 61mm Valve, a shorter and "cleaner" tubing the intake CFM grows from 116 to 465.
A other CAM (from the 1.6l ABU Motor from the VW 6N Polo), a DIY fan-type exhaust pipe, modified motorhead and higher compression (11:1), do the rest.
I hope i get the 145Nm @ 4500U/min @ a BSFC from 240g/kWh.
with the other tunings at the motor, i get much higher tourque and efficency (look at the diagramms)
ID:	20015  Click image for larger version
Old 05-03-2016, 04:30 AM   #22 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 51.57 mpg (US)
Hi,
It seems you are using an OEM intake setup. What vehicle is it from ?
Can we see pics of your fan type exhaust ?
What is the 61 mm valve ?
Old 05-03-2016, 08:14 AM   #23 (permalink)
Jack-Lee's Avatar
Hi,
the Intake is from a 1.6l ABU Engine from a VW Golf3
The Valve comes from a Golf4 with a 2.0l engine.
Old 05-03-2016, 09:56 AM   #24 (permalink)
OldContinents
By (61mm) valve do you mean throttle body ?
The HP figures are very impressive, all with OEM parts, a gas flowed head and compression ratio raise ?
Is the curve from actual measurement or a software output based on CFM increase ?
Old 05-03-2016, 12:04 PM   #25 (permalink)
Jack-Lee's Avatar
All with customized OEM Parts.
But the real torque are lower, because i didnt modified the valves.
The curves are made with a (good) software, just as the Stock curve (an there is allmost the same as the maesured one).
And the 61mm Valve is the main throttlevalve
The Following User Says Thank You to Jack-Lee For This Useful Post:
renault_megane_dci (05-04-2016)
Old 05-04-2016, 10:07 AM   #26 (permalink)
OldContinents
To your knowledge, could that part list be applied to the 1.4 from a 2000 A2 ?
I have red the A2 ECU is pretty different and is an issue when going for a turbo setup.
Any chance I could see a boost just with the inlet and cam ?
Old 05-04-2016, 03:35 PM   #27 (permalink)
Jack-Lee's Avatar
without a change in the ECU, the differences could be negativ. (wrong Lambda).
the A2 engine is pretty good, you couldnt make it so much better then mine cheap old thing. ECU modification could be the better way
Old 01-07-2017, 05:23 PM   #28 (permalink)
Jack-Lee's Avatar
Hi,
the project still in progress
Now i have a second "Polo" for the transition period. So i modified it a little bit.
Its another engine with only 1.0l and 45Hp.
Bigger throttle, other cam for more torque, modified intake manifold for better airflow.
+9hp @ 5500U/min and +12Nm @ 4000U/min and better fuel efficency
ID:	21126  Click image for larger version
ID:	21127  Click image for larger version
ID:	21128  Click image for larger version
ID:	21129  Click image for larger version
Old 01-07-2017, 06:48 PM   #29 (permalink)
OldContinents
Hi,
Appart from cam and throttle (holly molly difference !) I dont know what are the three other pics to be honest ...
Old 01-11-2017, 04:26 PM   #30 (permalink)
Jack-Lee's Avatar
18sec(stock) to 14sec. Nice difference:
But.. i would build in a MegaSquirt2 and MPI. More things i could play with.. Goal : over 110Nm and over 65Hp with higher fuel efficency
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
