Old 12-24-2009, 03:33 PM   #1 (permalink)
johnnymac's Avatar
Engine off switch in a Toyota Echo
I want to install a bush button momentary off switch somewhere, to turn off the engine in my 2001 Toyota Echo. Where in the wiring would I hook it up?
THANKS!!
Old 12-24-2009, 03:41 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Its always easiest IMO to cut wires inside the cabin so you don't have to run wires to the engine bay. Either way though works fine.
Here are options for kill switches:
Kill switch signal cutting options
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
